I’ve the same issue.
I’ve followed the instructions to the letter on The Things Kickstarter Gateway | The Things Stack for LoRaWAN (thethingsindustries.com)
Rob and Brian (elsewhere on these forums) have followed the same instructions but separately to see if it’s the way and individual is interpreting the instructions that’s causing it to fail - but no, all three have the same problem after upgrading TTKG’s from V2 to V3.
We’ve had long discussions among our local TTN/dev group and have spent weeks on this issue now and are still failing.
Via UART I can see the MON,MQTT etc flowing nicely.
I can see it accept packets and fwd them via MQTT but there’s nothing in the V3 gateway console, no joins, no uplinks - nothing.
We’ve around 14 of these TTKG gateways to upgrade and this is a serious concern, the Hull community has relied on these gateways after the local Council purchased them on behalf of the community to kickstart a TTN, not being able to move to V3 will effectively kill TTG in the area.
The community doesn’t have the funds to purchase another 14 gateways to replace them
Has anyone else come across this problem?
WIFI: IP Address: 0.0.0.0
SNTP: State change from 0 to 1
CB: INET: Gateway has WiFi
INET: State change to 2
INET: Connected to a network, waiting for DHCP lease, checking validity with ping
SNTP: State change from 1 to 2
WIFI: IP Address: 192...*
LORA: Wait init complete, waiting for application.
LORA: Changing state from 1 to 2
INET: State change to 3
INET: Ping probe
INET: Error sending probe on Eth
INET: Ping response from MRF24WN, set as default
INET: State change to 4
SNTP: State change from 2 to 3
SNTP: State change from 3 to 4
MON: SYS Stack size: 3965
MON: TCPIP Stack size: 3793
MON: APP Stack size: 8008
MON: LoRa Stack size: 3913
MON: heap usage: 179KB (188KB), free: 160KB
SNTP: State change from 4 to 5
SNTP: State change from 5 to 6
SNTP: State change from 6 to 7
INET: State change to 5
MAIN: Leaving state 2
MAIN: Entering state 3
CNFG: Load online user config state change to 4
HTTP: Close active socket 0
HTTP: Starting connection
HTTPS: Connection Opened: Starting TLS Negotiation
HTTP: Wait for TLS Connect
HTTP: TLS Connection Opened: Starting Clear Text Communication
HTTP: Got 1007 bytes
HTTP: Connection Closed
HTTP: Close active socket 1
CONF: Parsing response token: HTTP/1.1 200 OK
CONF: ROUTER URL: mqtts://eu1.cloud.thethings.network:8881
CNFG: Load online user config state change to 6
FREQ: APP_URL_Buffer: https://eu1.cloud.thethings.network/api/v2/frequency-plans/EU_863_870_TTN
HTTP: Got 1609 bytes
MON: SYS Stack size: 2837
MON: APP Stack size: 3292
MON: heap usage: 265KB (272KB), free: 73KB
CNFG: Load online user config state change to 7
CNFG: Configuring LoRa module
LORA: Changing state from 2 to 3
LORA: Starting reconfiguration
LGMD:Answer, cmd: 0x31, size: 1
LGMD:Command, cmd: 0x3A, size: 0
LGMD:Answer, cmd: 0x3A, size: 16
Version, hwrev: 1, major: 1, minor: 4, band: 1
Serial: 4C-47-38-34-33-31-36-30-30-33-36-35
LGMD:Command, cmd: 0x34, sie: 1
LGMD:Answer, cmd: 0x34, size: 1
LGMD:Command, cmd: 0x34, size: 6
LGMD:Command, cmd: 0x35, sie: 1
LGMD:Answer, cmd: 0x35, size: 1
LGMD:Command, cmd: 0x36, sie: 1
LGMD:Answer, cmd: 0x36, size: 1
LGMD:Command, cmd: 0x37, sie: 1
LGMD:Answer, cmd: 0x37, size: 1
LGMD:Command, cmd:0x40, size: 1
LGMD:Answer, cmd: 0x40, size: 1
LGMD:Command, cmd:0x31, size: 1
LGMD:Command, cmd: 0x30, size: 0
LGMD:Timeout on cmd: 0x30
LORA: configLora OK
LORA: Configuration succeeded
LORA: Starting operation
LORA: Changing state from 3 to 4
MON: LoRa Stack size: 3857
MON: heap usage: 189KB (272KB), free: 150KB
LGMD:Receiving unknown data
LORA: Changing state from 4 to 5
CNFG: Load online user config state change to 9
MAIN: Leaving state 3
MAIN: Entering state 4
FLASH: Loading FOTA Data
FIRM: Requesting key …
HTTP: Got 515 bytes
FIRM: Starting download
FIRM: available bytes: 79
FIRM: (Downloaded FOTA key) F7 ****************************************
FIRM: (Stored FOTA key) F7 ***************************************
FIRM: Firmware is already downloaded
MAIN: No new firmware available
MAIN: Leaving state 4
MAIN: Entering state 5
MQTT: GOT IP: 63.34.215.128
Connecting to: 63.34.215.128
MQTT: Connection Opened: Starting TLS Negotiation
MQTT: Wait for SSL Connect
MQTT: TLS ready: Connect MQTT
RQMQTT: Connected
MAIN: Gateway bridging
MQTT: Sending status packet
MQTT: Report reboot error: 0103
MQTT: Sending status succeeded: 0
MON: heap usage: 283KB (284KB), free: 55KB
MON: TCPIP Stack size: 3787
MQTT: Sending status succeeded: 1
LORA: Kick LoRa module with ACK after not acked it for 60s
LGMD:LORA: Accepted packet
MQTT: Sending UPLINK OK
MQTT: Sending status succeeded: 2
MQTT: Sending status succeeded: 6
LGMD:Rejected packet (0x11) *<----- is this a problem? *
LGMD:Rejected packet (0x11) <— This looks strange…
MQTT: Sending status succeeded: 7
This is an example of a lora sensor sending data - this can be seen to be accepted via the V3 application but when looking at the json payload it was fwd via a V2 gateway
The V3 isn’t mentioned and nothing shows up in the V3 gateway live data feed.
MQTT: Sending status succeeded: 23
I also see this on UART:
I have removed and re-seated the lora module, just in case, but it’s still the same.
Any help with the above problem will be appreciated as others are having exactly the same issue with TTKG gateways and the move V3.
