Johan,
console on TTN JSON console output
Kerlink Linux /mnt/fsuser-1/spf/var/log/spf.log
Aug 8 20:46:58 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:46:58 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:46:58 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:46:58 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:46:58 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:46:58 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:46:58 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:46:58 Wirnet local1.notice spf: ##### END #####
Aug 8 20:46:58 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:46:58 GMT","rxnb":1,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":56}}
Aug 8 20:46:58 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 45 ms
Aug 8 20:47:01 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 54.53 ms
Aug 8 20:47:06 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 51.99 ms
Aug 8 20:47:11 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 51.95 ms
Aug 8 20:47:16 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.61 ms
Aug 8 20:47:21 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.66 ms
Aug 8 20:47:26 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.65 ms
Aug 8 20:47:27 Wirnet local1.notice spf: INFO: Disabling GPS mode for concentrator's counter...
Aug 8 20:47:27 Wirnet local1.notice spf: INFO: host/sx1301 time offset=(1659988294s:381120µs) - drift=15µs
Aug 8 20:47:27 Wirnet local1.notice spf: INFO: Enabling GPS mode for concentrator's counter.
Aug 8 20:47:28 Wirnet local1.notice spf: ##### 2022-08-08 20:47:28 GMT #####
Aug 8 20:47:28 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:47:28 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:47:28 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:47:28 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:47:28 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:47:28 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:47:28 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:47:28 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.65 ms)
Aug 8 20:47:28 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:47:28 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:47:28 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:47:28 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:47:28 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:47:28 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:47:28 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:47:28 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:47:28 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:47:28 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:47:28 Wirnet local1.notice spf: ##### END #####
Aug 8 20:47:28 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:47:28 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:47:28 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 45 ms
Aug 8 20:47:31 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.65 ms
Aug 8 20:47:36 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.66 ms
Aug 8 20:47:41 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.62 ms
Aug 8 20:47:46 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.68 ms
Aug 8 20:47:51 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.70 ms
Aug 8 20:47:56 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.70 ms
Aug 8 20:47:58 Wirnet local1.notice spf: ##### 2022-08-08 20:47:58 GMT #####
Aug 8 20:47:58 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:47:58 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:47:58 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:47:58 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:47:58 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:47:58 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:47:58 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:47:58 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.70 ms)
Aug 8 20:47:58 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:47:58 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:47:58 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:47:58 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:47:58 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:47:58 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:47:58 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:47:58 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:47:58 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:47:58 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:47:58 Wirnet local1.notice spf: ##### END #####
Aug 8 20:47:58 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:47:58 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:47:58 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 44 ms
Aug 8 20:48:01 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.70 ms
Aug 8 20:48:06 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.66 ms
Aug 8 20:48:11 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.70 ms
Aug 8 20:48:16 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.69 ms
Aug 8 20:48:21 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.66 ms
Aug 8 20:48:26 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.64 ms
Aug 8 20:48:27 Wirnet local1.notice spf: INFO: Disabling GPS mode for concentrator's counter...
Aug 8 20:48:27 Wirnet local1.notice spf: INFO: host/sx1301 time offset=(1659988294s:381111µs) - drift=-9µs
Aug 8 20:48:27 Wirnet local1.notice spf: INFO: Enabling GPS mode for concentrator's counter.
Aug 8 20:48:28 Wirnet local1.notice spf: ##### 2022-08-08 20:48:28 GMT #####
Aug 8 20:48:28 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:48:28 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:48:28 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:48:28 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:48:28 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:48:28 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:48:28 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:48:28 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.64 ms)
Aug 8 20:48:28 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:48:28 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:48:28 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:48:28 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:48:28 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:48:28 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:48:28 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:48:28 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:48:28 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:48:28 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:48:28 Wirnet local1.notice spf: ##### END #####
Aug 8 20:48:28 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:48:28 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:48:28 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 43 ms
Aug 8 20:48:31 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.63 ms
Aug 8 20:48:36 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.64 ms
Aug 8 20:48:41 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.66 ms
Aug 8 20:48:46 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.68 ms
Aug 8 20:48:51 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.66 ms
Aug 8 20:48:56 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.74 ms
Aug 8 20:48:58 Wirnet local1.notice spf: ##### 2022-08-08 20:48:58 GMT #####
Aug 8 20:48:58 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:48:58 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:48:58 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:48:58 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:48:58 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:48:58 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:48:58 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:48:58 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.74 ms)
Aug 8 20:48:58 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:48:58 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:48:58 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:48:58 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:48:58 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:48:58 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:48:58 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:48:58 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:48:58 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:48:58 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:48:58 Wirnet local1.notice spf: ##### END #####
Aug 8 20:48:58 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:48:58 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:48:58 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 44 ms
Aug 8 20:49:01 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.76 ms
Aug 8 20:49:06 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.82 ms
Aug 8 20:49:11 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.79 ms
Aug 8 20:49:16 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.71 ms
Aug 8 20:49:21 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.68 ms
Aug 8 20:49:26 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.64 ms
Aug 8 20:49:27 Wirnet local1.notice spf: INFO: Disabling GPS mode for concentrator's counter...
Aug 8 20:49:27 Wirnet local1.notice spf: INFO: host/sx1301 time offset=(1659988294s:381112µs) - drift=1µs
Aug 8 20:49:27 Wirnet local1.notice spf: INFO: Enabling GPS mode for concentrator's counter.
Aug 8 20:49:28 Wirnet local1.notice spf: ##### 2022-08-08 20:49:28 GMT #####
Aug 8 20:49:28 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:49:28 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:49:28 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:49:28 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:49:28 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:49:28 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:49:28 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:49:28 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.64 ms)
Aug 8 20:49:28 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:49:28 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:49:28 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:49:28 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:49:28 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:49:28 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:49:28 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:49:28 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:49:28 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:49:28 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:49:28 Wirnet local1.notice spf: ##### END #####
Aug 8 20:49:28 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:49:28 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:49:28 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 44 ms
Aug 8 20:49:31 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.70 ms
Aug 8 20:49:36 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.68 ms
Aug 8 20:49:41 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.71 ms
Aug 8 20:49:46 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.73 ms
Aug 8 20:49:51 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.68 ms
Aug 8 20:49:56 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.70 ms
Aug 8 20:49:58 Wirnet local1.notice spf: ##### 2022-08-08 20:49:58 GMT #####
Aug 8 20:49:58 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:49:58 Wirnet local1.notice spf: # RF packets received by concentrator: 1
Aug 8 20:49:58 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Aug 8 20:49:58 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:49:58 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:49:58 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:49:58 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:49:58 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.70 ms)
Aug 8 20:49:58 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:49:58 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:49:58 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:49:58 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:49:58 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:49:58 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:49:58 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:49:58 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:49:58 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:49:58 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:49:58 Wirnet local1.notice spf: ##### END #####
Aug 8 20:49:58 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:49:58 GMT","rxnb":1,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:49:58 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 43 ms
Aug 8 20:50:01 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.66 ms
Aug 8 20:50:06 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.69 ms
Aug 8 20:50:11 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.69 ms
Aug 8 20:50:16 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.72 ms
Aug 8 20:50:21 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.73 ms
Aug 8 20:50:26 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.71 ms
Aug 8 20:50:27 Wirnet local1.notice spf: INFO: Disabling GPS mode for concentrator's counter...
Aug 8 20:50:27 Wirnet local1.notice spf: INFO: host/sx1301 time offset=(1659988294s:381179µs) - drift=67µs
Aug 8 20:50:27 Wirnet local1.notice spf: INFO: Enabling GPS mode for concentrator's counter.
Aug 8 20:50:28 Wirnet local1.notice spf: ##### 2022-08-08 20:50:28 GMT #####
Aug 8 20:50:28 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:50:28 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:50:28 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:50:28 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:50:28 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:50:28 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:50:28 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:50:28 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.71 ms)
Aug 8 20:50:28 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:50:28 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:50:28 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:50:28 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:50:28 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:50:28 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:50:28 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:50:28 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:50:28 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:50:28 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:50:28 Wirnet local1.notice spf: ##### END #####
Aug 8 20:50:28 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:50:28 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:50:28 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 43 ms
Aug 8 20:50:31 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.65 ms
Aug 8 20:50:36 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.64 ms
Aug 8 20:50:41 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 48.28 ms
Aug 8 20:50:46 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 48.33 ms
Aug 8 20:50:51 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 48.37 ms
Aug 8 20:50:56 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 48.32 ms
Aug 8 20:50:58 Wirnet local1.notice spf: ##### 2022-08-08 20:50:58 GMT #####
Aug 8 20:50:58 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:50:58 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:50:58 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:50:58 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:50:58 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:50:58 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:50:58 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:50:58 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 48.32 ms)
Aug 8 20:50:58 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:50:58 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:50:58 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:50:58 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:50:58 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:50:58 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:50:58 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:50:58 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:50:58 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:50:58 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:50:58 Wirnet local1.notice spf: ##### END #####
Aug 8 20:50:58 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:50:58 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:50:58 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 43 ms
Aug 8 20:51:01 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.70 ms
Aug 8 20:51:06 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.62 ms
Aug 8 20:51:11 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.61 ms
Aug 8 20:51:16 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.63 ms
Aug 8 20:51:21 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.60 ms
Aug 8 20:51:26 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.58 ms
Aug 8 20:51:27 Wirnet local1.notice spf: INFO: Disabling GPS mode for concentrator's counter...
Aug 8 20:51:27 Wirnet local1.notice spf: INFO: host/sx1301 time offset=(1659988294s:381242µs) - drift=63µs
Aug 8 20:51:27 Wirnet local1.notice spf: INFO: Enabling GPS mode for concentrator's counter.
Aug 8 20:51:28 Wirnet local1.notice spf: ##### 2022-08-08 20:51:28 GMT #####
Aug 8 20:51:28 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:51:28 Wirnet local1.notice spf: # RF packets received by concentrator: 1
Aug 8 20:51:28 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Aug 8 20:51:28 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:51:28 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:51:28 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:51:28 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:51:28 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.58 ms)
Aug 8 20:51:28 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:51:28 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:51:28 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:51:28 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:51:28 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:51:28 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:51:28 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:51:28 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:51:28 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:51:28 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:51:28 Wirnet local1.notice spf: ##### END #####
Aug 8 20:51:28 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:51:28 GMT","rxnb":1,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:51:28 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 43 ms
Aug 8 20:51:31 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.59 ms
Aug 8 20:51:36 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.63 ms
Aug 8 20:51:41 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.64 ms
Aug 8 20:51:46 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.85 ms
Aug 8 20:51:51 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.87 ms
Aug 8 20:51:56 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.90 ms
Aug 8 20:51:58 Wirnet local1.notice spf: ##### 2022-08-08 20:51:58 GMT #####
Aug 8 20:51:58 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:51:58 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:51:58 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:51:58 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:51:58 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:51:58 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:51:58 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:51:58 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.90 ms)
Aug 8 20:51:58 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:51:58 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:51:58 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:51:58 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:51:58 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:51:58 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:51:58 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:51:58 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:51:58 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:51:58 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:51:58 Wirnet local1.notice spf: ##### END #####
Aug 8 20:51:58 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:51:58 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:51:58 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 52 ms
Aug 8 20:52:01 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.94 ms
Aug 8 20:52:06 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.71 ms
Aug 8 20:52:11 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.69 ms
Aug 8 20:52:16 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.63 ms
Aug 8 20:52:21 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.61 ms
Aug 8 20:52:26 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.64 ms
Aug 8 20:52:27 Wirnet local1.notice spf: INFO: Disabling GPS mode for concentrator's counter...
Aug 8 20:52:27 Wirnet local1.notice spf: INFO: host/sx1301 time offset=(1659988294s:381298µs) - drift=56µs
Aug 8 20:52:27 Wirnet local1.notice spf: INFO: Enabling GPS mode for concentrator's counter.
Aug 8 20:52:28 Wirnet local1.notice spf: ##### 2022-08-08 20:52:28 GMT #####
Aug 8 20:52:28 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:52:28 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:52:28 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:52:28 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:52:28 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:52:28 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:52:28 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:52:28 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.64 ms)
Aug 8 20:52:28 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:52:28 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:52:28 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:52:28 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:52:28 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:52:28 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:52:28 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:52:28 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:52:28 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:52:28 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:52:28 Wirnet local1.notice spf: ##### END #####
Aug 8 20:52:28 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:52:28 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:52:28 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 43 ms
Aug 8 20:52:31 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.60 ms
Aug 8 20:52:36 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.64 ms
Aug 8 20:52:41 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.66 ms
Aug 8 20:52:46 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.73 ms
Aug 8 20:52:51 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.77 ms
Aug 8 20:52:56 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.75 ms
Aug 8 20:52:58 Wirnet local1.notice spf: ##### 2022-08-08 20:52:58 GMT #####
Aug 8 20:52:58 Wirnet local1.notice spf: ### [UPSTREAM] ###
Aug 8 20:52:58 Wirnet local1.notice spf: # RF packets received by concentrator: 0
Aug 8 20:52:58 Wirnet local1.notice spf: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Aug 8 20:52:58 Wirnet local1.notice spf: # RF packets forwarded: 0 (0 bytes)
Aug 8 20:52:58 Wirnet local1.notice spf: # PUSH_DATA datagrams sent: 1 (123 bytes)
Aug 8 20:52:58 Wirnet local1.notice spf: # PUSH_DATA acknowledged: 100.00%
Aug 8 20:52:58 Wirnet local1.notice spf: ### [DOWNSTREAM] ###
Aug 8 20:52:58 Wirnet local1.notice spf: # PULL_DATA sent: 6 (100.00% acknowledged, ping 47.75 ms)
Aug 8 20:52:58 Wirnet local1.notice spf: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Aug 8 20:52:58 Wirnet local1.notice spf: # RF packets sent to concentrator: 0 (0 bytes)
Aug 8 20:52:58 Wirnet local1.notice spf: # TX errors: 0
Aug 8 20:52:58 Wirnet local1.notice spf: # BEACON queued: 0
Aug 8 20:52:58 Wirnet local1.notice spf: # BEACON sent so far: 0
Aug 8 20:52:58 Wirnet local1.notice spf: # BEACON rejected: 0
Aug 8 20:52:58 Wirnet local1.notice spf: ### [JIT] ###
Aug 8 20:52:58 Wirnet local1.notice spf: /home/drd/jenkins/workspace/spf_release/lora_pkt_fwd/src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Aug 8 20:52:58 Wirnet local1.notice spf: ### [GPS] ###
Aug 8 20:52:58 Wirnet local1.notice spf: # GPS sync is disabled
Aug 8 20:52:58 Wirnet local1.notice spf: ##### END #####
Aug 8 20:52:58 Wirnet local1.notice spf: JSON up: {"stat":{"time":"2022-08-08 20:52:58 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"ping":48}}
Aug 8 20:52:58 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 44 ms
Aug 8 20:53:01 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.74 ms
Aug 8 20:53:06 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.68 ms
Aug 8 20:53:11 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.73 ms
Aug 8 20:53:16 Wirnet local1.notice spf: INFO: [down] PULL_ACK received in 47.71 ms
I have no node, I’m just preparing connection of the IoT gateway to TTN for my future usage…
If you tell me where, I can share some log files from the Kerlink Linux system. I believe, that some LoraWAN messages should be around me from different sources - I live in town…
Ondrej
