Setup Class of a device
Related to the class of the LoRAWAN device. Can I change it once the device has been activated? I want to change from Class A to Class C for making some tests. Or is it only possible to setup it in the activaion process?
Regards,
Joel
Have you checked the console to see if you can change the value?
Go to the End Device, General Settings and expand the ‘Network Layer’. It looks like you can tick the checkbox ‘Supports class C’ checkbox.
You will probably need to have the device rejoin to reset the active session. And the device needs to activate Class C.
Thank you. I will check it.
Regards,
Joel
Thank you. It works.
Regards,
Joel
