Setting up TTN Server Stack behind web proxy
I’m at the step in the TTN server stack setup where I run “make test” and this is failing when mqtt tries to connect to a server on the internet. I’m inside a corporate LAN and there is a web proxy available but not sure where in the make/build process I can configure a web proxy server. I’ve used the proxy already for downloading the dependencies and I’m hoping that once I get the server stack built and installed it won’t need to connect to the outside world. So, has anyone tried to build and run the TTN server stack behind a web proxy?
-Larry
I’m also facing the same issue.
-Rejeesh
