There are already quite a few topic on the matter, however I haven’t managed to find any solution.
I have followed the instructions in ic880a-gateway . The only thing I have changed due to 4,6 pins of being in a fan, I have put the power to 2, 9.
I have also enabled spi as it is mentioned:
sudo raspi-config nonint get_spi
0 (enabled)
I run
sudo systemctl status ttn-gateway
● ttn-gateway.service - The Things Network Gateway
Loaded: loaded (/lib/systemd/system/ttn-gateway.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since Sun 2021-04-04 23:36:30 EEST; 1s ago
Process: 15300 ExecStart=/opt/ttn-gateway/bin/start.sh (code=exited, status=1/FAILURE)
Main PID: 15300 (code=exited, status=1/FAILURE)
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: Ghoststream data is disabled
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: Radiostream data is enabled
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: Statusstream data is enabled
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: Beacon is disabled
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: Monitor is disabled
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: Contact email configured to "symeon.mattes@gmail.com"
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: Description configured to "ttn-ic880a"
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: Successfully contacted server router.eu.thethings.network
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: INFO: [main] Starting the concentrator
Apr 04 23:36:30 ttn-gateway ttn-gateway[15300]: ERROR: [main] failed to start the concentrator
I checked /var/log/syslog and I receive:
Apr 4 23:38:08 ttn-gateway systemd[1]: ttn-gateway.service holdoff time over, scheduling restart.
Apr 4 23:38:08 ttn-gateway systemd[1]: Stopping The Things Network Gateway...
Apr 4 23:38:08 ttn-gateway systemd[1]: Starting The Things Network Gateway...
Apr 4 23:38:08 ttn-gateway systemd[1]: Started The Things Network Gateway.
Apr 4 23:38:08 ttn-gateway ttn-gateway[15626]: /opt/ttn-gateway/bin/start.sh: line 5: echo: write error: Device or resource busy
Apr 4 23:38:08 ttn-gateway ttn-gateway[15626]: /opt/ttn-gateway/bin/start.sh: line 6: /sys/class/gpio/gpio25/direction: No such file or directory
Apr 4 23:38:08 ttn-gateway ttn-gateway[15626]: /opt/ttn-gateway/bin/start.sh: line 7: /sys/class/gpio/gpio25/value: No such file or directory
Apr 4 23:38:08 ttn-gateway ttn-gateway[15626]: /opt/ttn-gateway/bin/start.sh: line 9: /sys/class/gpio/gpio25/value: No such file or directory
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: /opt/ttn-gateway/bin/start.sh: line 11: /sys/class/gpio/gpio25/value: No such file or directory
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: /opt/ttn-gateway/bin/start.sh: line 13: echo: write error: Invalid argument
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: *** Poly Packet Forwarder for Lora Gateway ***
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: Version: 2.1.0
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: *** Lora concentrator HAL library version info ***
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: Version: 3.1.0; Options: native;
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Little endian host
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: found global configuration file global_conf.json, parsing it
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: lorawan_public 1, clksrc 1
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Configuring TX LUT with 16 indexes
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: gateway MAC address is configured to AA555A0000000000
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Found 2 servers in array.
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Server 0 configured to "127.0.0.1", with port up "1680" and port down "1681"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Server 1 configured to "iot.semtech.com", with port up "1680" and port down "1680"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Found 5 system calls in array.
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: System command 0: "df -m"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: System command 1: "free -h"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: System command 2: "uptime"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: System command 3: "who -a"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: System command 4: "uname -a"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: monitor hostname or IP address is configured to "127.0.0.1"
Apr 4 23:38:09 ttn-gateway systemd[1]: ttn-gateway.service: main process exited, code=exited, status=1/FAILURE
Apr 4 23:38:09 ttn-gateway systemd[1]: Unit ttn-gateway.service entered failed state.
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: monitor port is configured to "2008"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: ghost hostname or IP address is configured to "127.0.0.1"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: ghost port is configured to "1918"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: downstream keep-alive interval is configured to 10 seconds
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: statistics display interval is configured to 30 seconds
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: upstream PUSH_DATA time-out is configured to 100 ms
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: packets received with a valid CRC will be forwarded
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: packets received with a CRC error will NOT be forwarded
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: packets received with no CRC will NOT be forwarded
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: GPS serial port path is configured to "/dev/ttyAMA0"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: SSH path is configured to "/usr/bin/ssh"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: SSH port is configured to 22
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: HTTP port is configured to 80
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: NGROK path is configured to "/usr/bin/ngrok"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Reference latitude is configured to 10.000000 deg
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Reference longitude is configured to 20.000000 deg
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Reference altitude is configured to -1 meters
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: GPS is enabled
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Using fake GPS coordinates instead of real.
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: antenna_gain 0 dBi
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Upstream data is enabled
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Downstream data is enabled
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Ghoststream data is disabled
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Radiostream data is enabled
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Statusstream data is enabled
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Beacon is disabled
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Monitor is disabled
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Platform configured to "IMST + Rpi"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Contact email configured to "operator@gateway.tst"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Description configured to "Update me"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: found local configuration file local_conf.json, parsing it
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: redefined parameters will overwrite global parameters
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: local_conf.json does not contain a JSON object named SX1301_conf
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: gateway MAC address is configured to B827EBFFFE048ECF
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Found 1 servers in array.
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Server 0 configured to "router.eu.thethings.network", with port up "1700" and port down "1700"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Reference latitude is configured to 38.036345 deg
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Reference longitude is configured to 23.757590 deg
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Reference altitude is configured to 0 meters
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Contact email configured to "symeon.mattes@gmail.com"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Description configured to "ttn-ic880a"
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: Successfully contacted server router.eu.thethings.network
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: INFO: [main] Starting the concentrator
Apr 4 23:38:09 ttn-gateway ttn-gateway[15626]: ERROR: [main] failed to start the concentrator
I tried to create the gpio25 directory
echo 25 >/sys/class/gpio/export
bash: echo: write error: Device or resource busy
In ls -la /sys/class/gpio I have:
drwxrwx--- 2 root gpio 0 Apr 4 22:16 .
drwxr-xr-x 51 root root 0 Apr 4 22:23 ..
-rwxrwx--- 1 root gpio 4096 Apr 4 23:44 export
lrwxrwxrwx 1 root gpio 0 Apr 4 22:16 gpiochip0 -> ../../devices/platform/soc/3f200000.gpio/gpio/gpiochip0
lrwxrwxrwx 1 root gpio 0 Apr 4 22:16 gpiochip100 -> ../../devices/gpiochip2/gpio/gpiochip100
lrwxrwxrwx 1 root gpio 0 Apr 4 22:16 gpiochip128 -> ../../devices/gpiochip1/gpio/gpiochip128
-rwxrwx--- 1 root gpio 4096 Apr 4 23:44 unexport
Furthermore in cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-53, parent: platform/3f200000.gpio, pinctrl-bcm2835:
gpio-4 ( |w1 ) in lo
gpio-25 ( |ads7846_pendown ) in hi
gpiochip2: GPIOs 100-101, brcmvirt-gpio, can sleep:
gpio-100 ( |? ) out lo
gpiochip1: GPIOs 128-135, brcmexp-gpio, can sleep:
gpio-135 ( |? ) in lo
I have doubled checked also the cables and the antena, it seems to be ok. The concentrator has a constant LED on.
Any suggestions?
Im running the packet forwarder of
