I am an absolute beginner in Lora. That’s why I propably already have made several stupid mistakes.
The idea is to transport sensorreadings every half hour (BME280; temperature, humidity, pressure) to the Things Network. Therefore, the sensor is plugged into a Dragino shield (LA66 LoRaWAN Shield). An example sketch provided by Dragino on their website (Dropbox - Log-Temperature-Sensor-and-send-data-to-TTN - Simplify your life), is modified by including the code for the sensorreadings.
Unfortunately, it is a struggle to include the pressure reading in the payload. I assume, this must be a long integer (temperature and humidity are short integers). Whatever I have done so far, it was not a succes….
Below the code which include sensor readings for temperature and humidity (correct values):
void loop() {
//digitalWrite(BEE_VCC, HIGH); // keep rn2483 running
// pick up sensor value
float celsius = bme.readTemperature();
float percentage = bme.readHumidity();
char sensor_data_buff[128]="\0";
//translate float value to int 16 bit and long to get rid of the .
int16_t temperature = (int16_t)(celsius * 100);
int16_t humidity = (int16_t)(percentage * 100);
long pressure = bme.readPressure();
//confirm status,Fport,payload length,payload(HEX)
snprintf(sensor_data_buff,128,"AT+SENDB=%d,%d,%d,%02X%02X%02X%02X",0,2,4,(short)(temperature)>>8 & 0xFF,(short)(temperature) & 0xFF,(short)(humidity)>>8 & 0xFF,(short)(humidity) & 0xFF);
ss.println(sensor_data_buff);
When pressure included, pressure value is zero….:
void loop() {
snprintf(sensor_data_buff,128,"AT+SENDB=%d,%d,%d,%02X%02X%02X%02X",0,2,4,(short)(temperature)>>8 & 0xFF,(short)(temperature) & 0xFF,(short)(humidity)>>8 & 0xFF,(short)(humidity) & 0xFF,(long)(pressure)>>8 & 0xFF,(long)(pressure) & 0xFF);
The following payload formatter (Javascript) is used:
var temperature = (input.bytes[0] << 8 | input.bytes[1]);
var humidity = (input.bytes[2] << 8 | input.bytes[3]);
var pressure = (input.bytes[4] << 8 | input.bytes[5]);
return {
data: {
Temperature: temperature / 100,
Humidity: humidity / 10,
Pressure: pressure / 100
What could possibly be wrong?
Kind regards,
Pim.
