Hello.
My Polysense sensor send ONLY “accept join-request” and “forward uplink data message”.
I see both messages on “application” TTN (live data).
Does not send any more data.
Please, could you help me?
Thanks!
d.
Hello.
Thanks!
d.
I think I have the same problem with GPS device (LGT-92).
Here is the screenshoot:
Hey! I also have the same problem. Did you figure it out?
How far are you from the gateway?
Wat is the RSSI?
Hi all,
I also have the similar problem. Sometimes even my device could not join a gateway (personal gateway) and I am testing the device just next to gateway. Sometimes it is sending message, sometimes only join accept message, and sometimes even join is unsuccessfull. I am using Seeedunio Lorawan board. When it sends a message, SNR is mostly negative too. I do not know it is about board, gateway or server? I have tested with sevaral different Seeedunio boards and th problem is the same. Do you have any suggestions?
If you searched a small little bit and maybe read the last dozen or so post, you will have the solution maybe.
Did you try this?
WIth a technology designed for Long Range! Search forum on recommended placements when developing…
Thanks! And sorry for taking your time. Actually I spent much time in the forum but may be with the wrong keywords! I will look for optimum replacements and search a bit more.
What is the RSSI as logged in the application console?
RSSI of the last successful message of one of the device was -117. But I have several devices that I could not manage to get successful join message or forward uplink message for some of them.
Unsuccessful one
Sorry, probably I ve missed some points but I could only see the RSSI"s of the successful ones now. When I ll access to devices tomorrow, I will connect them and update the RSSI information here. Thanks for the help and your time!
Thank you so much! This thread seems really helpful!
Hi again. It seems that closeness to the gateway was the main problem! Even one device is close, I think it also effects the join of the other devices too. Now all my devices are far away from gateway and they are all working. Thank you so much!
