Hi, I was wondering how I would send my sensor data over to TTN? I am able to send my gps data, but I want to also send my mpu data as well as a button press and I am unsure how I would go about it. Here below is the code that I currently have:
PROJECT
// THIS IS FOR LORAWAN
#include <ESP32_LoRaWAN.h>
#include "Arduino.h"
// THIS IS FOR GPS
#include <TinyGPSPlus.h>
// THIS IS FOR BUTTON
#include <Arduino.h>
#include <OneButton.h>
// THIS IS FOR THE MPU_6050
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu;
// The TinyGPS++ object
TinyGPSPlus gps;
#define RXD2 17
#define TXD2 2
#define BUTTON_PIN 12 // ESP32 GIOP12 pin connected to button's pin
#define BUZZER_PIN 13 // ESP32 GIOP13 pin connected to buzzer's pin
#define MOTOR_PIN 33 // ESP32 GPIO33 pin connected to vibrator motor pin
/*license for Heltec ESP32 LoRaWan, quary your ChipID relevant license: http://resource.heltec.cn/search */
uint32_t license[4] = {0x000000, 0x000000, 0x000000, 0x000000};
/* OTAA para*/
uint8_t DevEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t AppEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t AppKey[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
/* ABP para*/
uint8_t NwkSKey[] = { 0x15, 0xb1, 0xd0, 0xef, 0xa4, 0x63, 0xdf, 0xbe, 0x3d, 0x11, 0x18, 0x1e, 0x1e, 0xc7, 0xda, 0x85 };
uint8_t AppSKey[] = { 0xd7, 0x2c, 0x78, 0x75, 0x8c, 0xdc, 0xca, 0xbf, 0x55, 0xee, 0x4a, 0x77, 0x8d, 0x16, 0xef, 0x67 };
uint32_t DevAddr = ( uint32_t )0x007e6ae1;
/*LoraWan channelsmask, default channels 0-7*/
uint16_t userChannelsMask[6] = { 0x00FF, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000 };
/*LoraWan Class, Class A and Class C are supported*/
DeviceClass_t loraWanClass = CLASS_C;
/*the application data transmission duty cycle. value in [ms].*/
uint32_t appTxDutyCycle = 15000;
/*OTAA or ABP*/
bool overTheAirActivation = true;
/*ADR enable*/
bool loraWanAdr = true;
/* Indicates if the node is sending confirmed or unconfirmed messages */
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
// retrieve some usefull values from GPS library
float latitude, longitude, altitudes;
Number of trials to transmit the frame, if the LoRaMAC layer did not
receive an acknowledgment. The MAC performs a datarate adaptation,
according to the LoRaWAN Specification V1.0.2, chapter 18.4, according
to the following table:
Transmission nb | Data Rate
1 (first) | DR
2 | DR
3 | max(DR-1,0)
4 | max(DR-1,0)
5 | max(DR-2,0)
6 | max(DR-2,0)
7 | max(DR-3,0)
8 | max(DR-3,0)
Note, that if NbTrials is set to 1 or 2, the MAC will not decrease
the datarate, in case the LoRaMAC layer did not receive an acknowledgment
uint8_t confirmedNbTrials = 8;
/*LoraWan debug level, select in arduino IDE tools.
None : print basic info.
Freq : print Tx and Rx freq, DR info.
Freq && DIO : print Tx and Rx freq, DR, DIO0 interrupt and DIO1 interrupt info.
Freq && DIO && PW: print Tx and Rx freq, DR, DIO0 interrupt, DIO1 interrupt and MCU deepsleep info.
uint8_t debugLevel = LoRaWAN_DEBUG_LEVEL;
/*LoraWan region, select in arduino IDE tools*/
LoRaMacRegion_t loraWanRegion = ACTIVE_REGION;
static void prepareTxFrame( uint8_t port ) {
latitude = gps.location.lat();
longitude = gps.location.lng();
altitudes = gps.altitude.meters();
uint32_t LatitudeBinary = ((latitude + 90) / 180) * 16777215;
uint32_t LongitudeBinary = ((longitude + 180) / 360) * 16777215;
uint16_t altitudeGps = altitudes; // altitudeGps in meters, alt from tinyGPS is float in meters
if (altitudes < 0) altitudeGps = 0; // unsigned int wil not allow negative values and warps them to huge number, needs to be zero'ed
appDataSize = 8;//AppDataSize max value is 64 ( src/Commissioning.h -> 128 )
appData[0] = ( LatitudeBinary >> 16 ) & 0xFF;
appData[1] = ( LatitudeBinary >> 8 ) & 0xFF;
appData[2] = LatitudeBinary & 0xFF;
appData[3] = ( LongitudeBinary >> 16 ) & 0xFF;
appData[4] = ( LongitudeBinary >> 8 ) & 0xFF;
appData[5] = LongitudeBinary & 0xFF;
// altitudeGps in meters into unsigned int
appData[6] = ( altitudeGps >> 8 ) & 0xFF;
appData[7] = altitudeGps & 0xFF;
// THE START OF BUZZER/BUTTON/VIBRATION CODE
// The ESP32 has 16 channels which can generate 16 independent waveforms
// We'll just choose PWM channel 0 here
const int TONE_PWM_CHANNEL = 0;
class Button {
private:
OneButton button;
int value;
public:
explicit Button(uint8_t pin): button(pin) {
button.attachClick([](void *scope) {
((Button *) scope)->Clicked();
}, this);
button.attachLongPressStart([](void *scope) {
((Button *) scope)->LongPressed();
}, this);
void Clicked() {
ledcWrite(0, 0);
digitalWrite(MOTOR_PIN, LOW);
Serial.println("short-press-DO NOT SEND NOTIFICATIONS");
value++;
void LongPressed() {
ledcWriteNote(TONE_PWM_CHANNEL, NOTE_C, 4);
digitalWrite(MOTOR_PIN, HIGH);
Serial.println("LongPress");
void handle() {
button.tick();
Button button(BUTTON_PIN);
// THE START OF MPU CODE
// Variables will change:
int lastState = LOW; // the previous state from the input pin
int currentState; // the current reading from the input pin
unsigned long pressedTime = 0;
unsigned long releasedTime = 0;
const int MPU_addr = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
float ax = 0, ay = 0, az = 0, gx = 0, gy = 0, gz = 0;
//int data[STORE_SIZE][5]; //array for saving past data
//byte currentIndex=0; //stores current data array index (0-255)
boolean fall = false; //stores if a fall has occurred
boolean trigger1 = false; //stores if first trigger (lower threshold) has occurred
boolean trigger2 = false; //stores if second trigger (upper threshold) has occurred
boolean trigger3 = false; //stores if third trigger (orientation change) has occurred
byte trigger1count = 0; //stores the counts past since trigger 1 was set true
byte trigger2count = 0; //stores the counts past since trigger 2 was set true
byte trigger3count = 0; //stores the counts past since trigger 3 was set true
int angleChange = 0;
// Add your initialization code here
void setup() {
Serial.println(F("Starting..."));
Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
Serial.begin(115200);
while (!Serial);
SPI.begin(SCK, MISO, MOSI, SS);
Mcu.init(SS, RST_LoRa, DIO0, DIO1, license);
deviceState = DEVICE_STATE_INIT;
// FOR THE BUZZER/VIBRATION
ledcAttachPin(BUZZER_PIN, TONE_PWM_CHANNEL);
pinMode(MOTOR_PIN, OUTPUT);
// FOR THE MPU
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
// The loop function is called in an endless loop
void loop() {
button.handle();
switch ( deviceState ) {
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
LoRaWAN.generateDeveuiByChipID();
#endif
LoRaWAN.init(loraWanClass, loraWanRegion);
break;
case DEVICE_STATE_JOIN:
LoRaWAN.join();
break;
case DEVICE_STATE_SEND:
// This sketch displays information every time a new sentence is correctly encoded.
while (Serial2.available() > 0)
if (gps.encode(Serial2.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while (true);
// gps gets sent
prepareTxFrame( appPort );
LoRaWAN.send(loraWanClass);
deviceState = DEVICE_STATE_CYCLE;
break;
case DEVICE_STATE_CYCLE:
// Schedule next packet transmission
txDutyCycleTime = appTxDutyCycle + randr( -APP_TX_DUTYCYCLE_RND, APP_TX_DUTYCYCLE_RND );
LoRaWAN.cycle(txDutyCycleTime);
deviceState = DEVICE_STATE_SLEEP;
break;
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass, debugLevel);
break;
default:
break;
mpu_read();
//2050, 77, 1947 are values for calibration of accelerometer
// values may be different for you
ax = (AcX - 2050) / 16384.00;
ay = (AcY - 77) / 16384.00;
az = (AcZ - 1947) / 16384.00;
//270, 351, 136 for gyroscope
gx = (GyX + 270) / 131.07;
gy = (GyY - 351) / 131.07;
gz = (GyZ + 136) / 131.07;
// calculating Amplitute vactor for 3 axis
float Raw_AM = pow(pow(ax, 2) + pow(ay, 2) + pow(az, 2), 0.5);
int AM = Raw_AM * 10; // as values are within 0 to 1, I multiplied
// it by for using if else conditions
Serial.println(AM);
//Serial.println(PM);
//delay(500);
if (AM <= 2 && trigger2 == false) { //if AM breaks lower threshold (0.4g)
trigger1 = true;
Serial.println("TRIGGER 1 ACTIVATED");
if (trigger1 == true) {
trigger1count++;
if (AM >= 12) { //if AM breaks upper threshold (3g)
trigger2 = true;
Serial.println("TRIGGER 2 ACTIVATED");
trigger1 = false; trigger1count = 0;
if (trigger2 == true) {
trigger2count++;
angleChange = pow(pow(gx, 2) + pow(gy, 2) + pow(gz, 2), 0.5); Serial.println(angleChange);
if (angleChange >= 30 && angleChange <= 400) { //if orientation changes by between 80-100 degrees
trigger3 = true; trigger2 = false; trigger2count = 0;
Serial.println("TRIGGER 3 ACTIVATED");
if (trigger3 == true) {
trigger3count++;
if (trigger3count >= 10) {
//delay(10);
if ((angleChange >= 0) && (angleChange <= 10)) { //if orientation changes remains between 0-10 degrees
fall = true; trigger3 = false; trigger3count = 0;
else
{ //user regained normal orientation
Serial.println("TRIGGER 3 DEACTIVATED");
if (fall == true)
{ //in event of a fall detection
Serial.println("FALL DETECTED");
fall = false;
if (trigger2count >= 6)
{ //allow 0.5s for orientation change
Serial.println("TRIGGER 2 DECACTIVATED");
if (trigger1count >= 6)
{ //allow 0.5s for AM to break upper threshold
Serial.println("TRIGGER 1 DECACTIVATED");
delay(100);
void mpu_read() {
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX = Wire.read() << 8 | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY = Wire.read() << 8 | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ = Wire.read() << 8 | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
// GPS PRINT TO SERIAL MONITOR
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
else
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
else
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
else
Serial.println();
This is the customer JavaScript I have for the uplink:
function Decoder (bytes) {
var _lat = ((bytes[0] << 16) + (bytes[1] << 8) + bytes[2]) / 16777215.0 * 180.0 - 90;
var _lng = ((bytes[3] << 16) + (bytes[4] << 8) + bytes[5]) / 16777215.0 * 360.0 - 180;
var _alt = (bytes[6] << 8) + bytes[7];
return {
gps_lat: _lat,
gps_lng: _lng,
gps_alt: _alt,
Thank you in advance for the help!
