Hello everyone, trying to send data to TTN. Did so successfully using "mydata = “Hello World” ". Tried to send different values as in Humidity values and it just shows me
"Text": "\u0000
in the Fields section in TTN Data.
A portion of the code im using:
// hum = dht.readHumidity();
// temp= dht.readTemperature();
mydata[0] = dht.readHumidity();
Serial.print("Sizeof mydata - ");
Serial.println(sizeof(mydata));
Serial.print("Sizeof mydata[0] - ");
Serial.println(sizeof(mydata[0]));
LMIC_setTxData2(1, mydata[0], sizeof(mydata[0]), 0);
Serial.println(F(“Packet queued”));
in that code, mydata[0] does store correctly the value for humidity so i dont know what im doing wrong now since im passing the values correctly through the function. Maybe something wrong with my decoder in TTN?
return{
Text: String.fromCharCode.apply(null,bytes)
Thank you in advance if u reply
My best regards
Rodrigo Oliveira
