Send analog data to the server through LCI
An error is reported when I try to use the CLI to send analog data
F:\lorawan-stack-cli_3.15.3_windows_amd64\lorawan-stack-cli_3.15.3_windows_amd64>ttn-lw-cli simulate application-uplink lht65n001 eui-70b3d57ed0052973 frm-payload ‘0xCC070A1F02540209D97FFF’
WARN Multiple IDs found in arguments, considering the first
error:pkg/errors:validation (invalid uplink_message: embedded message failed validation)
reason=embedded message failed validation
field=uplink_message
name=ApplicationUpValidationError
correlation_id=ec04534dc30c42b3bca2897778888cb7
— error:pkg/errors:validation (invalid settings: embedded message failed validation)
field=settings
name=ApplicationUplinkValidationError
correlation_id=70224ce7ef434c48949187288c1d42c3
— error:pkg/errors:validation (invalid data_rate: embedded message failed validation)
field=data_rate
name=TxSettingsValidationError
correlation_id=d922693aff88447c86f8723f4adf4f98
— error:pkg/errors:validation (invalid modulation: value is required)
reason=value is required
field=modulation
name=DataRateValidationError
correlation_id=5592e4f45a514cc7800447d2908eb321
I have the same problem that you :
C:>ttn-lw-cli simulate application-uplink loramodbus2023 devsim01 frm-payload ‘MTkwMjAwQTAwQTAyMDBGQQ==’
correlation_id=50baa00d04624417a89fab6d6f827b8a
— error:pkg/errors:validation (invalid settings: value is required)
field=settings
correlation_id=91ab2bf07fd0491fa4b762fe9a5c3a68
Has anybody found a solution for this problem ?
VSL
