I’m new and would like to start and provide a gateway in my area. (I’m thinking to use it for home automation and GPS tracking in second time)
I can deploy an antenna + outdoor gateway near my house. I’m IT engineer so linux / raspberry is not a problem for me. If the product is opensource, it will be perfect
thanks in advance for your guidance and I continue to search
The fair access policy limits you to 30 seconds of air time per day, so if the thing you are tracking is at a long distance and the node goes to long distance mode (Spreading Factor 12) your limited to around 23 packets or transmissions per day …
If the thing you are tracking is in close, then you can use shorter range and less air time packets (Spreading Factor 7) and can have around 500 packets per day.
