Yes, acknowledged transmission. If these fail to get ack multiple times assume you need to re-join. Just make sure to use at least 3 acked transmissions with a couple of hours in between to eliminate chances of not getting an ack because the the back-end is experiencing issues.
Hello everyone,
I want to test the ATAES132A chip by giving input key from Arduinoā¦Do I need to attach any buffer or logic level convertor to interface both the devicesā¦ If yes how it can be doneā¦
Moreover, while sending the key what library I have to install for ATAES132 chip and does the data is send simply using SPI communication protocolā¦
