SD-IOT (Software Defined IoT)
I am researching about a solution (gateway and software) defined by software like SDN (software defined network) or SDWAN (software defined WAN) but oriented to IoT gateways. The gateway needs to manage the control plane independently of the management plane and this has to communicate with the controller (external software) by some standard southbound interface like NETCONF, SNMP, etc…
The main purpose of this kind of solution is to reduce maintenance costs, implementation hours and centralize the management in massive IoT networks for ISPs.
Do you know if there’s some solution of this type in the market?
This is the TTN forum, so it’s specific the the LoRaWAN network that is TTN.
Other subjects aren’t on topic
maybe rolaguard
thanks dear
