I’m having some troubles with LoRa network for SAMR34. At the moment, I need to configure some specifics parameters on SAMR34 The server is configured in AU915, and it uses the first 8 channels from 915.2 MHz with 200KHz of bandwidth to UPLINK and the lasts 8 channels from 923,3 MHz with 500 KHz of bandwidth to DOWNLINKS, furthermore, it uses RX1 and RX2 with 1s and 2s respectively. I don’t found where can I select these parameters in no one place in the example code and also don’t find documentation saying how can we change these parameters.
I’m using the Atmel example PROVISIONING of LORAWAN MOTE APPLICATION, the activation mode is ABP and I have success sending uplinks, but downlinks and receive confirmations still not working, I think it occurs because the channels are not configured correctly. If someone could help me I’ll be very thankful
@descartes Thank you, but maybe have somebody here that maked the configuration I need, and probably works in every plataform, independent it’s TTN or another. Regards
