I have received some Laird RS1xx nodes…and their documentation says that it will remain in state activation until an uplink message with empty payload receives a timestamp in epoch format.
How do you provide such a timestamp if you use the HTTP integration?
Just do a POST to the supplied downlink URL with an array element called “timestamp” ?
Or does the RS1xx needs a special format?
Edit: This doesn’t seem to work…sending timestamp as payload_raw:
You need to send it base64 encoded as payload_raw…not as timestamp but with the RTC format the RS1xx expects…sample PHP code to generate it (keep it simple and stupid style ;o):
Did you check the amount of downlinks used by the devices? When I tested months ago the device used a downlink for each uplink which is at odds with the TTN fair access policy.
These units are currently essentially fixed function driven by an original development programme requirement, short of opening up (they are glue sealed) and hacking the hardware there isn’t any easy way to re-purpose. I understand some early release software is in development and due to be demoed that will allow more flexibility, and re-programming capabilities and hence opportunity to eliminate (or significantly reduce) confirmed download requirements, but that seems to be some way of public release status as yet. I’m hoping to see as soon as ready for release and will advise if/when I see it…
Also FYI from what I could see based on quick limited tests (Am open/hoping to be proved wrong!) ‘anyone’ who pulls the android/BT management app to manage these devices & who gets close enough that they can see a given device over BT is basically able to ‘pair’ & change device settings and potentially hi-jack or sabotage set-up!..am still investigating and looking at more secure options, as was hoping to use a bunch on a pending project…actually a ‘nice’ product
Security by obscurity might be option for you if out in the sticks as you say
FYI I recently met with Laird to discuss options & suggest features and a series of updates are indeed pending…Laird will phase in new features/options capabilities over next few weeks and summer. 1st new release (before end of month?) will make confirmed uplinks optional & remove need for an initial timestamp before sending payloads (Set up then no longer needs e.g supporting Node-Red instance to hand timestamp). Also looks like they will make a release with Cayenne LPP format an option - I expect in 2nd or 3rd update to follow
Comment back on another thread
dbrgn
Unfortunately Cayenne LPP is severely underspecified and will result in different incompatible implementations Maybe someone should create a better specification of a format like that. (I already thought about starting something…)
But that’s offtopic.
My response and call to action re payloads?:-
Agreed but its a good start - Cayenne seems v popular with TTNers and well understood so me thinks pat on the back to Laird if they do go that way as option. Indeed in recent meet question was asked what other payload/standards might be desired/supported so if folks have a view let me know and I will try to co-ordinate a response/feedback to Laird prod management & eng/firmware teams…
…off topic as you say…
So anyone reading this thread with ideas for desired payload standards please shout!..
To UPDATE: Last week I received a draft release (awating final sign off and release) of new f/w build, new/updated Smart-Phone management app (android .apk) and draft Application Note covering device integration with Cayenne. It came in whilst on vac and doing overseas LoRa trials so no immediate chance to test and evaluate but from what I can see new phone app allows user to choose Laird or Cayenne payload format and to choose confirm payload or not acknowledge payload delivery.
Will need to play in next few days to see if timestamp still needed to initiate payload deliveries (I dont believe it is… ).
Laird team working hard to get all to released status, signed off and pushed out to user base…will update here when I hear its ready to go
Happy to confirm new app installed fine on spare phone and then allowed option to download the test release f/w that enabled the new options.
Running in Laird payload format the ‘confirmed’ option is on and greyed out - looks like you have to use ack with Laird version (at least for now). (see earlier packets in image below). Then switched payload format using the app to enable Cayenne vs Laird and confirmed no longer greyed out and can chose either confirmed or unconfirmed - later packets in image show Cayenne format and unconfirmed
Better yet the payloads are coming through without having to set up a (e.g. Node-RED) server to send an initial timestamp before the payloads start rolling in…
Now a happy geek and next steps set up Cayenne integration per draft App Note
I ran into this today after picking up my first LoRa devices (Laird Gateway and Sensor) and haven’t been able to get this to work. I was following the example provided by @davorin and wasn’t able to start receiving data. I ran the code in php, ended up with a payload and passed the following json object via downlink:
Unfortunately, I ended up in the same place he initially did. It sends the payload down every time an uplink comes in and I never actually get the sensor to send useful data back to me. I ended up deleting my device (in TTN) and setting it back up to get rid of the constant downlinks.
I am having the same problem with my RS191, “payload: [not provided]”. The firmware version available is V3.2 and it don´t have no payload format option.
Any news about the release date or any roadmap? I mean Octuber, 18 and no news
I understand there is an imminent code/release review (expected to be final) so fingers crossed we see something new for general use in days/next week?!
