RPi Ic880A; GPS; Base Station; update GPS-Position from status messages in TTS-Console
i have an RPi with ic880a and a GPS module!
As software runs the basic station with the LNS protocol!
Is the GPS information also transmitted with the protocol?
In the TTS (V3) on the gateway console there is under location no GPS position when i took the option: location source / Update from status messages!
Greetings
E_T
A question that may fit the topic: When a GW use base station so LNS protocol,
is the GPS information also transmitted with the protocol?
The GW has a GPS-Module!
E_T
Yes, we understand that your gateway has a GPS and you want that GPS to tell the network server where the gateway is.
Can you point to somewhere in the LNS documentation where it transmits the GPS co-ordinates?
Have you searched the forum for this, because I know what one of the TTI senior engineers has to say on this matter.
And please don’t double post, I appreciate you’ve not had a response on this thread.
