I try to communicate to a LoStick over serial. When I communicate with the python mini terminal that is provided with the lostick repository I can control the RN2483 with no problem. When I try to command the RN2483 from a C++ program i continue to get invalid_param.
This makes me conclude that communication is received by the RN2483.
When I verify the data using a USB-UART-TTL converter and a logic analyser I see the command sys get ver\r\n correctly appearing with right speed, and settings (8N1).
My question is:
Is anyone aware of some timing restrictions like delay when communicating with RN2483? I have not found any in the documentation other than with autobaud.
Doing serial communications correctly in C/C++ can be trickier than it at first seems. You might try some intermediate tests against pyserial, or even using ltrace or USB packet sniffing to see what is really happening.
In particular pay attention to things like line endings, and invalid assumptions about the chunks and timing with which responses will arrive.
Default assumption should really be that the issue is either in your code, or the beliefs about what exactly your code needs to do in order to accomplish a goal. Blaming the module would be appropriate only when you can demonstrate that the same operations differing only in a specific way (such as transmit timing) which should not matter are producing a different result, and your current debug efforts seem quite far from doing that.
Nice. Not my cup of tea, but just in case it’s not a totally stupid idea: would it be possible to create the same image for the Python mini terminal?
Hmmm, yes, I’d say that looks the same, including the total time of about 2 ms.
The vertical scale differs, but I guess you understand that difference?
And we’re seeing sys get vdd versus sys get ver, but I’d also not expect the first to throw invalid_param, and I guess you tried other commands from C++ as well?
Currently I can reproduce the same problem with putty. With putty after de CR I have to enter ctrl-J to produce a newline char. this results in invalid_param.
Maybe that’s actually only for server-side CR, hence not adding a LF when you press Return in PuTTY. Or maybe not. Sorry if I caused confusion there…
My problem is that all my captures with the logic analyser are on a USB-TTL-serial converter, not on the actual lostick. I cannot access that hardware now. the problem occurs as soon as I use the lostick.
I just verified that both my dongle and the lostick use CH340T_SSOP20.
