I’m still working on getting the RHF76-052 to work consistently with TTN, and while the upgrade to 2.1.18 has helped a lot, there are still issues. While the device will now join, it will only ever send one packet. After that, all requests to send another packet say they complete but do nothing.
I recompiled the packet forwarder on my RAK831 so it would show the packets, and here is what I have:
##### 2018-05-31 07:34:06 GMT #####
### [UPSTREAM] ###
# PUSH_DATA datagrams sent: 1 (153 bytes)
# PUSH_DATA acknowledged: 100.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (100.00% acknowledged)
# TX errors: 0
### [GPS] ###
# GPS sync is disabled
##### END #####
JSON up: {"stat":{"time":"2018-05-31 07:34:06 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"pfrm":"IMST + Rpi","mail":"","desc":""}}
INFO: [up] PUSH_ACK for server bridge.us-west.thethings.network received in 25 ms
JSON up: {"rxpk":[{"tmst":572679724,"time":"2018-05-31T07:34:07.253499Z","chan":4,"rfch":1,"freq":903.100000,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":9.0,"rssi":-53,"size":23,"data":"AJ3xANB+1bNwQgBTAGmyeEdwDJelFvY="}]}
INFO: [down] for server bridge.us-west.thethings.network serv_addr[ic]PULL_RESP received :)
JSON down: {"txpk":{"imme":false,"tmst":577679724,"freq":925.7,"rfch":0,"powe":20,"modu":"LORA","datr":"SF10BW500","codr":"4/5","ipol":true,"size":17,"ncrc":true,"data":"IF7F4ewcSjYAja66+UFyNAI="}}
INFO: [down] a packet will be sent on timestamp value 577679724
JSON up: {"rxpk":[{"tmst":578214676,"time":"2018-05-31T07:34:12.789147Z","chan":1,"rfch":0,"freq":902.500000,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","lsnr":12.2,"rssi":-54,"size":17,"data":"QAAkAiaAAQAI98gnQBDg3Vw="}]}
INFO: [down] for server bridge.us-west.thethings.network PULL_ACK received in 24 ms
JSON down: {"txpk":{"imme":false,"tmst":580214676,"freq":923.3,"rfch":0,"powe":20,"modu":"LORA","datr":"SF12BW500","codr":"4/5","ipol":true,"size":22,"ncrc":true,"data":"YAAkAiaKAAADQAIAcQM1AP8BKBjJCg=="}}
INFO: [down] a packet will be sent on timestamp value 580214676
I’d like to better understand what is flying back and forth, which leads me to my question: How can I decrypt the payload data so that I can parse it?
Thanks!
