I have a problem with a Dragino LT-22222-L.
Is it possible to restart the LT-22222-L using Payload Uplink?
The analog values are no longer displayed correctly.
Thanks you for your help
Gregor
Gregor
What does the documentation on the device tell you? It would be a downlink not uplink so you may have looked in wrong location if only looking at uplink data structures……
Looked in my notes I can only see a note to either do it from the reset button or AT.
ATZ: Trig a reset of the MCU
AT+FDR: Reset Parameters to Factory Default, Keys Reserve
