I am building a system that connects with multiple lpwan type networks. We are integrating with TTN and I am having problems with the tokens and permission.
I use Oauth2.0 with my client-id, etc… and I get back a code which my backend server uses to get an access token. I then create an application. This part works fine but when I try to doing anything with the application it gives me a 403 saying I don’t have setting permissions on the application. Steps I have tried
- I tried to create an access_key using the access_keys array in the application post.
created: new Date(),
rights: [
'settings',
'devices',
'messages:up:r',
'messages:down:w'
'access_keys': [
'name': 'stupid',
'rights': [
'settings',
'devices',
'messages:up:r',
'messages:down:w'
This is ignored and the default access_key (without setting permissions) is created.
euis: [ '70B3D57ED00118AB' ],
created: '2018-08-19T00:02:08.338Z',
rights: [ 'settings', 'delete', 'collaborators', 'devices' ],
collaborators:
[ { username: '<>',
email: '<>',
rights: [Array] } ],
access_keys:
[ { name: 'default key',
key: 'ttn-account-v2.Ci5yegihynqSsy5HhI1PrqQMnVZUXaK61Ga9AhsgEWQ',
_id: '5b78b380f5fd6d003a4a6706',
rights: [Array] } ] }
- I tried doing a POST on the api/v2/applications/{id}/access-keys as described in https://www.thethingsnetwork.org/docs/network/account/api.html#post-applicationsapp_idaccess-keys
It again gives me a 403 and says I don’t have setting permission on the application.
rights: [
'settings',
'devices',
'messages:up:r',
'messages:down:w'
Error on adding Keys: {"code":403,"error":"You do not have access to for right settings to application blah"}(403)
- I tried 2 again using the default key created from the POST in 1 with the same result.
I check my token in jwt.io and it has ‘apps’ permission so I don’t understand what I am doing wrong. If I have to go to the console to create a access_key, then that isn’t going to work.
"sub": "<>",
"iss": "ttn-account-v2",
"iat": 1534634803,
"type": "user",
"client": "<>",
"scope": [
"profile",
"apps",
"components",
"gateways"
"interchangeable": true,
"username": "<>",
"email": "<>,
"created": "2018-06-20T16:04:49.767Z",
"name": {
"first": "<>",
"last": "<>"
"valid": true,
"_id": "5b2a7b216a41ae0030a911ed",
"exp": 1534638463
Help?
