Hi!
I am brand new to TTN and LoRa in general, I’m trying to build a LoRa Gateway with a Raspberry Pi 3 b+, I am guiding myself through the following tutorial:
And I have read that there are certain problems regarding single-channel gateways, specifically with the downlink, Due to this, I have followed the following tutorial:
When I run the gateway service, it shows this:
but in TTN my gateway is “not connected”, and I´m trying to connect a node to the gateway but there’s no response, I do not know if the problem is the gateway or the node.
If somebody can help me, I would be very grateful.
I see …
Listening at SF7 on 916.800
Listening at SF7 on 868.100
that can’t be right I think, check your global_conf.json
Here is my global_conf.json, I changed the second frequency equal to the first
But still doesn’t working, in ttn it looks like not connected:
if you want to connect to ttn you must set that server to true
13.66.229.235 is the ip I get to connect to us-west.thethings.network, I already tried with the domain name, but it does not work either.
bridge.us-west.thethings.network
It works, thank you very much!
