[Resolved] Firmware upgrade RHF76-052 via YMODEM
I am working with a Seeeduino LoRaWAN with Rhf76-052 chipset. I would like to upgrade the firmware to the latest version(2.1.16) with lsx (since I am working with a non windows system)
I try:
lsz --ymodem --1k -vv rhf76-052am-v2.1.16-20171203.ebin.bin > /dev/cu.usbmodem1431
resulting in a:
Retry 0: Timeout on pathname
Does someone know how to upgrade the firmware with YMODEM without putty? I think minicom would be fine too…
If anyone stumbled upon this and would like to perform an firmware upgrade via YMODEM interface. This is how it worked for me:
  1. brew install lrzsz (if you are on a mac)
  2. Connect seeduino to your computer
  3. enter: screen /dev/cu.usbmodem1431 115200 (you need to replace the usb device with the appropriate one)
  4. switch to firmware mode on the node by pressing DFU button on the node
  5. type <ctrl-a>:
  6. enter: lsz --ymodem -w 8 -vv rhf76-052am-v2.1.16-20171203.ebin.bin
After some tries the firmware was upgraded successfully. Here I got the information how to connect with screen to a serial device:
ok… so 'resolved ’ ?
Jep, resolved - at least the node is upgrade to the latest version. I think I tried the steps above several times before it worked out…
