I tried and failed to get a new Multitech Conduit connected using Basics Station, decided to delete the gateway and start again, only I can’t proceed until the EUI is purged, hence would be grateful if someone could take a look at this.
EUI: 00800000A0008232
Thanks,
Andrew
PS. Any pointers to a set of instructions that work would be much appreciated!
Hoping that someone at TTN may be checking in now and again, given that CE is not supported per se, I’d assumed that firing off an e-mail or similar would not be received well.
I see, I’d assumed it was for commercial support and not clicked through, but thank you for the prompt, polite and eminently helpful response!
D’oh! I had read a previous post, which appears to have led me down the wrong path and I should have read others else simply distinguished ID from EUI. Thanks. I also see your source of frustration
