Hello everyone,
I am programming an application with which it should be possible to manage devices. For this purpose, there is the Devices API:
https://www.thethingsindustries.com/docs/reference/api/end_device/
I wouldlike to query and change the device properties regarding Lorawan (AppEUI, DevEUI, nwk_s_key, etc.). Unfortunately, I get an error back for the following call:
GET https://eu1.cloud.thethings.network/api/v3/applications/<my-app-id>/devices/<my-device-id>?field_mask=resets_join_nonces,network_server_address,application_server_address,net_id,application_server_id,application_server_kek_label,network_server_kek_label,claim_authentication_code,root_keys
Accept: application/json
Authorization: Bearer <my-api-token>
"code": 3,
"message": "error:pkg/rpcmiddleware/validator:field_mask_paths (forbidden path(s) in field mask)",
"details": [
"namespace": "pkg/rpcmiddleware/validator",
"name": "field_mask_paths",
"message_format": "forbidden path(s) in field mask",
"attributes": {
"forbidden_paths": [
"resets_join_nonces",
"net_id",
"application_server_id",
"application_server_kek_label",
"network_server_kek_label",
"claim_authentication_code",
"root_keys"
"correlation_id": "ff4507de630c4bb495a082de35d8cfe3",
"code": 3
In the console, this call is executed successfully. The API token has all permissions.
If I remove the forbidden paths, the request is successful, but the device data regarding Lorawan is missing. What am I doing wrong?
