I am using HC-SR04 Ultrasonic Sensor along with RFM95 module(HPD13A) and Arduino Uno .
I successfully registered my GATEWAY, APPLICATION and DEVICE on TTN .
I am using LMIC-ARDUINO(matthijskooijman) Library & TTN-ABP code.
I want to see the distance data of Ultrasonic sensor on TTN.
So, i need PAYLOAD FUNCTION.
Can you please tell me how can i write the PAYLOAD for the Ultrasonic sensor?
It will be a great help for me.
Thank you.
â I am using HC-SR04 Ultrasonic Sensor along with RFM95 module(HPD13A) and Arduino Uno .
show some code you use to read the sensor combined with the lmic code first.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <HCSR04.h>
//#include <U8x8lib.h>
const int trigPin = 12;
const int echoPin = 11;
// defines variables
long duration;
int distance;
// LoRaWAN NwkSKey, network session key
// This is the default Semtech key, which is used by the early prototype TTN
// network.
static const PROGMEM u1_t NWKSKEY[16] = { 0x56, 0xE3, 0x4B, 0xDC, 0xEC, 0xE1, 0x87, 0x88, 0x90, 0xE9, 0xCA, 0xBE, 0xCB, 0x93, 0xCE, 0x36 };
// LoRaWAN AppSKey, application session key
// network.
static const u1_t PROGMEM APPSKEY[16] = { 0x0F, 0xFD, 0x92, 0x5C, 0xA1, 0x87, 0xAF, 0xB2, 0x6F, 0x3E, 0xBE, 0xBD, 0x63, 0xE5, 0x3C, 0x4C };
// LoRaWAN end-device address (DevAddr)
static const u4_t DEVADDR = 0x26011B27 ; // <-- Change this address for every node!
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
static uint8_t mydata[] = "distance!";
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 5,
.dio = {2, 3,4},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
break;
case EV_BEACON_FOUND:
break;
case EV_BEACON_MISSED:
break;
case EV_BEACON_TRACKED:
break;
case EV_JOINING:
break;
case EV_JOINED:
break;
case EV_RFU1:
Serial.println(F("EV_RFU1"));
break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
case EV_TXCOMPLETE:
Serial.println(F("distance: "));
if (LMIC.dataLen) {
Serial.println(LMIC.dataLen);
// Schedule next transmission
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
// data received in ping slot
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
default:
break;
void do_send(osjob_t* j){
digitalWrite(trigPin, LOW);
delay(100);
digitalWrite(trigPin, HIGH); // Sets the trigPin on HIGH state for 10 micro seconds
delay(100);
duration = pulseIn(echoPin, HIGH); // Reads the echoPin, returns the sound wave travel time in microseconds
distance= duration*0.034/2; // Calculating the distance
if(distance>=5 && distance<=15)
Serial.print("distance: "); // Prints the distance on the Serial Monitor
Serial.println(distance);
delay(100);
} else {
void setup() {
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
Serial.begin(9600);
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
// LMIC init
os_init();
LMIC_reset();
#ifdef PROGMEM
LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
#else
LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
#endif
#if defined(CFG_eu868)
// Set up the channels used by the Things Network, which corresponds
// to the defaults of most gateways. Without this, only three base
// channels from the LoRaWAN specification are used, which certainly
// works, so it is good for debugging, but can overload those
// frequencies, so be sure to configure the full frequency range of
// your network here (unless your network autoconfigures them).
// Setting up channels should happen after LMIC_setSession, as that
// configures the minimal channel set.
// NA-US channels 0-71 are configured automatically
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI); // g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK, DR_FSK), BAND_MILLI); // g2-band
// TTN defines an additional channel at 869.525Mhz using SF9 for class B
// devices' ping slots. LMIC does not have an easy way to define set this
// frequency and support for class B is spotty and untested, so this
// frequency is not configured here.
#elif defined(CFG_us915)
// but only one group of 8 should (a subband) should be active
// TTN recommends the second sub band, 1 in a zero based count.
// https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
LMIC_selectSubBand(1);
#endif
LMIC_setLinkCheckMode(0);
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
LMIC_setDrTxpow(DR_SF7,14);
// Start job
do_send(&sendjob);
void loop()
os_runloop_once();
unsigned int distance = HCSR04.distance();
mydata[0] = highByte(distance);
mydata[1] = lowByte(distance);
Sir, please give me some suggestions about the code.
I am doing similar project but with jsn-r04t 2.0 ultra sonic sensor. Looking to figure out how to decode it too
Maybe this project can help you out. Let me know if it does.
Can I see your project?
