Hi
I have created the end device with ABP method, initially when transmitting the payload for the first time.
I can see the data in end device live data.
But when trying on second time and more I cannot see the live data.
And again if I delete the end device and create the new, I can see the live data.
And its happening the same way, so whenever I try to send the data multiple times its not working.
What will be the solution for this?
Forum search is your friend…not the 1st time this has come up, what have you found what have you tried? When registering did you populate console with all 8 frequencies, so backend knows you have them set or is backend trying to send Mac commands etc to set these on your device and your device unable to handle commands correctly etc. What device? what firmware, which library etc. … detail details …details…and logs please (note correctly formatted or Nick might bite!)
Sounds like a FCnt-problem. But that’s not a problem - it’s a feature.
