@descartes
In your reference for the collaborators set subcommands (and may-be others) the -XXX-id is missing where XXX is main entity. So for gateways the --gateway-id is not listed. And for organizations the --organization-id is missing from the set page. In the TTN documentation these entries are listed in the main command ‘XXX collaborators’ as ‘The following flags are also available in sub-commands’, that probably causes you not to list them either, but as in your reference we’re looking at a different page per command it would be good if the information is available on page for the sub command as well imho.
