Reassign device to another application with the console
Hello all
Is there a possibility to reassign a device to different application with the console?
The current situation is having received a sensor from a manaufactorer with preconfigured APP EUI, APP Key, which was taken and sent to manufactorer from the “wrong” application.
Is there a solution other than sending the sensor back?
Many thanks
Hy,
An App can have multiple APP_EUI´s. So you can simply add the APP_EUI to your app and use the device. Please take care to remove the devices from the old APP before adding it to the new APP.
