Hi all,
first of all i am new since a week with Lora.
My name is Andi, i am 56 and leave in Mannheim Germany. Sorry, for not being perfect in formatting the post.
What i did so far: bought 2 Heltec 868MHz Lora V2 Board, and the Raspi head to create a simple one channel repeater while i wait for my “real” one to arrive.
I used different Arduino OTAA sources on the boards and they can connect to a 2km Gateway when outdoor and good antenna (takes long time). So i assume they are working ok.
But my Raspi Gateway seems not to “see” them at all.
It seems to get some packets occasionally :
stat update: 2021-02-06 22:09:08 GMT 2 packets received, 0 packet sent…
CE0 Packet RSSI: -62, RSSI: -49, SNR: -4, Length: 23 Message:rxpk update: {“rxpk”:[{“tmst”:803106720,“freq”:868.1,“chan”:0,“rfch”:0,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“rssi”:-62,“lsnr”:-4.0,“size”:23,“data”:“AEnMw+C+gLNwwICOUTTuZAB3XnDP4jM=”}]}
stat update: 2021-02-06 22:09:38 GMT 3 packets received, 0 packet sent…
stat update: 2021-02-06 22:10:08 GMT 3 packets received, 0 packet sent…
But why are my Nodes connecting to farer gateways instead to my raspi ? I know that it is only one channel and i configured it to 868.1MHz
Also i checked in the Serial Monitor that the Nodes also cycle through 868,1 and thy do.
Raspi-GW is connected to TTN but seems i heave an issue on my RX/TX side.
Not sure what info is needed to give you the best picture about my setup.
Maybe start screen from packet forwarder:
pi@Pi2Lora:~/dual_chan_pkt_fwd $ sudo ./dual_chan_pkt_fwd
server: .address = router.eu.staging.thethings.network; .port = 1700; .enable = 1
server: .address = router.eu.thethings.network; .port = 1700; .enable = 0
Gateway Configuration
** your name (a@b.c)**
** Dual channel pkt forwarder**
** Latitude=0.00000000**
** Longitude=0.00000000**
** Altitude=10**
** Interface: eth0**
Trying to detect module CE0 with NSS=6 DIO0=7 Reset=3 Led1=unused
CE0: SX1276 detected, starting.
Trying to detect module CE1 with NSS=6 DIO0=7 Reset=3 Led1=unused
CE1: SX1276 detected, starting.
Gateway ID: b8:27:eb:ff:ff:e8:7a:2c
Listening at SF7 on 868.100000 Mhz.
Listening at SF7 on 868.300000 Mhz.
**INFO: Successfully contacted server router.eu.staging.thethings.network (port 1700) **
INFO: [down] Thread activated for server router.eu.staging.thethings.network
stat update: 2021-02-06 22:32:22 GMT no packet received yet
Any ideas ?
best regards and have a nice weekend.
Andi
