Hey everybody. How can i find the library of rn2483 in raspberry pi pico??
You just talk to it over UART using AT commands… LoRaWAN stack built in so no ‘library’ needed in that sense as you won’t be running stack on the Pico…
Yes just AT(-like) commands via a serial port. The datasheet is quite clear and complete. But if you want an example you can have a look at my Arduino implementation here:
