I have the same problem, I’m way to far from being an expert but as I see, you are using ABP method?
The problem, people have told me that is because generic devices are no longer support, I am usin a TTGO LoRa32 V1 and Lmic library to implement ttn-abp method. Is this similar to your case? Let me know if you find a solution.
So far I am going to try a different solution without using TTN, the other option is trying to use a supported product, such as helect, arduino uno, etc. I’ll try that later.
People who are wrong, mistaken, misleading and vague.
This works
Heltech maybe, but not “supported” in the sense you may think that it may appear on some list of devices that are known to work - if anything they are a bit fiddly.
Arduino Uno, well sure, I can make them work using the latest LMIC & the right configuration. But an Uno is definitely not on the list as it takes special magic to make it work.
You said TTGO LoRa32 V1 works with LMIC in order to suit in TTN. Hereby, the problem must be my Dragino LG02 gateway?
Besides of that, can you recommend me how can I get it done in another server (consider my lg02 gateway is not allowed to ttn)? I only what to monitorize CO2 levels at long distance.
Dragino LG02 Gateway
TTGO LoRa32 V1
Thanks for any advice you can give me. This is an academic project I am working on.
One very important thing you should learn is that a Dragino LG02 isn’t a gateway. It’s not suitable for TTN and must not be connected to TTN or TTS CE.
There are some threads in this forum dealing with this problem.
As you’ve been told above, a Single or Dual Channel Packet Forwarder is not supportable on TTN and is disruptive to other users so please disconnect it and buy a full 8 channel gateway.
Even the vendor on the product page says it is not suitable for LoRaWAN.
