Hi guys,
I have recently received a RAK833 concentrator and finally got it working with the legacy LoRa-net packet forwarder. Starting from the LoRa-net github repo, I have forked both lora_gateway and packet_forwarder to make it compatible with the RAK833. This is just a preliminary version, with some workaround to make it compatible and of course there is still something to fix and it is intended just for testing purposes.
Instruction
1 - Setting up working direcotry
cd ~
mkdir git
cd git
git clone https://github.com/RAKWireless/RAK831_LoRaGateway.git
git clone GitHub - nrdmtt/packet_forwarder: A LoRa packet forwarder is a program running on the host of a LoRa gateway that forwards RF packets receive by the concentrator to a server through a IP/UDP link, and emits RF packets that are sent by the server.
git clone GitHub - nrdmtt/lora_gateway: Driver/HAL to build a gateway using a concentrator board based on Semtech SX1301 multi-channel modem and SX1257/SX1255 RF transceivers.
2 - Build and install libmpsse
sudo apt-get install libftdi-dev
cd RAK831_LoRaGateway/libmpsse/src/
sudo ./configure --disable-python
make clean
make
sudo make install
sudo ldconfig
3 - Build lora gateway
cd ~/git/lora_gateway/
make all
4 - Build packet forwarder
cd ~/git/packet_forwarder/
make all
Starting the packet forwarder,
cd ~/git/packet_forwarder/lora_pkt_fwd and
sudo ./lora_pkt_fwd
Tests
The project has been tested with both TTN and also with a private lora servers like https://www.loraserver.io/. With both lora server, packets are received correctly.
The project has been built both on x86 debian and raspbian. Just remember to install building tools.
Some tips
Before starting the packet forwarder, remember to modify your global_conf.json and local_conf.json, that you find in ~/git/packet_forwarder/lora_pkt_fwd, to reflect your configuration.
You must modify library.cfg (~/git/lora_gateway/libloragw) to reflect you configuration. I have a RAK833 for the EU market (868 band ), so if you have a different model, before building lora gateway, update library.cfg
You have to first build lora gateway and then you can build the packet forwarder
If you change the directory of the project, update make files accordingly.
