I have a RAK831 module in combination with a Raspberry pi 3+ and wanted to connect it to the thing network. I followed these instructions.
Everything was executed correctly on the Raspberry. However, it is always displayed as Disconnected in the console. Does anyone here have an idea what else I can try?
Start by unmasking your EUI & ID - these are visible in the network & over the air…and will allow us to check status etc.
What do the local logs show - are you e.g. setting Reset PIN asignment correctly such that the Concentrator card starts…it does start doesnt it?
Which packet forwarder are you using? SMTC classic UDP, Jac Kersings MPPF or Basic Station or…
Note GW ID (In the console) doesnt have to be the auto generated version which is GW EUI derived - and can already see doesnt match - it can be anything yu want withing field and character limits e.g. ‘zioo-gateway-001’ etc. provided it is not an ID chosen by another user…
Also are you using an interface card e.g. the official RAK interface or say one from another source like the Hallard/ch2i versions or… or just using Dupont cables?
Those instructions are for TTN V2. We are at V3 these days. You need to use the gateway configuration file you can download from the TTN gateway page. Put that on your RPi and make sure it doesn’t attempt to overwrite it with a version from GitHub.
I have replaced all of them with the downloaded global_confg.json but is doesn’t work. Maybe my RAK 831 had a problem. I dont know. Sorry i am a newbie in this area.
When I come to save the two files for review both try to save as local_ …have you accidentaly posted same file twice (look the same & same size - might be genuinly same but…) even though calling one as global_ in your post?
Which is where we were 4 -5 hrs+ ago As you seem to be using dupont cables to connect Pi to conc card alternate is check how set in the firmware and move the wire on the Pi connector… be sure not to confuse Pi pins with GPIO with BCM pins etc…
I think I have destroyed the conc card. I unintentionally started the pi earlier even though the antenna was not connected to the conc card. Maybe the transceiver is burnt out because the conc card only has the 2 standard leds on…
Unlikely. It would still start but just have RF issues. You need to check SPI is properly enabled and the reset pin. And if you are using DuPont wires, check each and every one of them. I’ve had too many of them that were broken. Switched to wire wrapping for reliable prototyping and real PCBs for production stuff.
And of course you need to check you did wire things correctly.
I have plenty of RPi based gateways, some with the RAK831 card, running smoothly.
You may also find you have to dial down the bus speed - though is usually only an issue where the designers inserted level shifters that then failed to support full speed… should not be an issue with direct wired, but may be worth considering if you wiring is too long or poorly done or suffering from some local interference - best as above is use a proper inteface pcb (RAK has an official one), Like Jac I have dozens of these configs (various PI’s +RAK831 -using PCB, not duponts) deployed with no major issues, it will be the details that get you!. Sadly I moved the last of my TTN Zurich/Technoblogy SMTC UDP style builds (similar to PiSupply but without direct wiring) over to alternate form and switched over PF to Jac’s MPPF last year otherwise I would follow paths, copy example file for you to follow and PM to you…
