RAK831 - RPi3 - failed to start concentrator
Jac,
I’ve recreated it on resin.io ; ineed a production image
  • The overlay i’ve used is pi3-disable-bt
  • And then enable uart
After that the device file /dev/sttyAMA0 is talking NMEA
And the packet forwarder is starting. And uses the GPS!
Thanks!
Hi Koen,
How do you disable the bt?
and enable the uart in resin.io?
Thanks,
Vincent
Thanks very much
this worked well for me.
just a little problem. i need to do this every time that i reboot my pi.
i tried to modify the rc.local, it didnt work.
is there any way to save these changes?
Hello Everyone.
I have the same problem: “main failed to start the concentrator”.
The message appeared after I power supplied Raspberry with insufficient current, can it be related? In the following the logs. Thank you in advance to anyone who can help me!
May 2 19:51:09 B827EBFFFEEDDFFF ttn-gateway[330]: INFO: Successfully contacted server router.eu.thethings.network
May 2 19:51:09 B827EBFFFEEDDFFF ttn-gateway[330]: INFO: [main] Starting the concentrator
May 2 19:51:09 B827EBFFFEEDDFFF ttn-gateway[330]: ERROR: [main] failed to start the concentrator
May 2 19:51:09 B827EBFFFEEDDFFF systemd[1]: ttn-gateway.service: Main process exited, code=exited, status=1/FAILURE
May 2 19:51:09 B827EBFFFEEDDFFF systemd[1]: ttn-gateway.service: Unit entered failed state.
May 2 19:51:09 B827EBFFFEEDDFFF systemd[1]: ttn-gateway.service: Failed with result ‘exit-code’.
May 2 19:51:15 B827EBFFFEEDDFFF systemd[1]: ttn-gateway.service: Service hold-off time over, scheduling restart.
May 2 19:51:15 B827EBFFFEEDDFFF systemd[1]: Stopped The Things Network Gateway.
May 2 19:51:15 B827EBFFFEEDDFFF systemd[1]: Started The Things Network Gateway.
May 2 19:51:15 B827EBFFFEEDDFFF ttn-gateway[627]: /opt/ttn-gateway/gateway-remote-config /opt/ttn-gateway/bin
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: Already up-to-date.
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: HEAD is now at c7caf0a Merge pull request #1285 from bakoad/patch-3
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: /opt/ttn-gateway/bin
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: [TTN Gateway]: Use Gateway EUI B827EBFFFEEDDFFF based on eth0
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: *** Poly Packet Forwarder for Lora Gateway ***
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: Version: 2.1.0
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: *** Lora concentrator HAL library version info ***
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: Version: 3.1.0; Options: native;
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Little endian host
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: found global configuration file global_conf.json, parsing it
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: lorawan_public 1, clksrc 1
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Configuring TX LUT with 16 indexes
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: gateway MAC address is configured to AA555A0000000000
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Found 2 servers in array.
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Server 0 configured to “127.0.0.1”, with port up “1680” and port down “1681”
May 2 19:51:17 B827EBFFFEEDDFFF ttn-gateway[627]: INFO: Server 1 configured to
This is usually caused by a missing reset signal to the RAK831.
