As always, I am happy about the nice support platform here and I hope you can help me. I have two RPI 3B+ LoRa gateways running on Rak831 and Rak2243. I have followed the latest installation guide:
The Gateways show up nicely on TTN, the signals are forwarded by the gateway and the received signal counter goes up. However, I get no acknowledge for my Adeunis Field Tester device. Using an LP1301 from Dragino, it works.
The Gateway also don’t get a GPS fix even though there are clearly GPS modules connected. That’s not such a big issue but the acknowledge error bothers me. Please see the logs for following commands attached:
sudo systemctl status ttn-gateway
journalctl -f
Good morning everyone. I’d just like to notify you that it’s working fine now after readding the Adeunis field tester on TTN. The node was the problem, not the gateway. Now, I am just stuck with getting a GPS fix, which seems to be harder for RAK modules than for Dragino ones.
