This is the global_conf.json file that is currently on the RPi, and was generated by the RAKwireless install procedure. I changed one line since my last post:
“gateway_ID”: “E45F01FFFEB95A01”,
It originally had “gateway_ID”: “AA555A0000000000”,
    "SX130x_conf": {
        "com_type": "SPI",
        "com_path": "/dev/spidev0.0",
        "lorawan_public": true,
        "clksrc": 0,
        "antenna_gain": 0, /* antenna gain, in dBi */
        "full_duplex": false,
        "fine_timestamp": {
            "enable": false,
            "mode": "all_sf" /* high_capacity or all_sf */
        "radio_0": {
            "enable": true,
            "type": "SX1250",
            "freq": 904300000,
            "rssi_offset": -215.4,
            "rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d": 2162.56, "coeff_e": 0},
            "tx_enable": true,
            "tx_freq_min": 923000000,
            "tx_freq_max": 928000000,
            "tx_gain_lut":[
                {"rf_power": 12, "pa_gain": 1, "pwr_idx": 6},
                {"rf_power": 13, "pa_gain": 1, "pwr_idx": 7},
                {"rf_power": 14, "pa_gain": 1, "pwr_idx": 8},
                {"rf_power": 15, "pa_gain": 1, "pwr_idx": 9},
                {"rf_power": 16, "pa_gain": 1, "pwr_idx": 10},
                {"rf_power": 17, "pa_gain": 1, "pwr_idx": 11},
                {"rf_power": 18, "pa_gain": 1, "pwr_idx": 12},
                {"rf_power": 19, "pa_gain": 1, "pwr_idx": 13},
                {"rf_power": 20, "pa_gain": 1, "pwr_idx": 14},
                {"rf_power": 21, "pa_gain": 1, "pwr_idx": 15},
                {"rf_power": 22, "pa_gain": 1, "pwr_idx": 16},
                {"rf_power": 23, "pa_gain": 1, "pwr_idx": 17},
                {"rf_power": 24, "pa_gain": 1, "pwr_idx": 18},
                {"rf_power": 25, "pa_gain": 1, "pwr_idx": 19},
                {"rf_power": 26, "pa_gain": 1, "pwr_idx": 21},
                {"rf_power": 27, "pa_gain": 1, "pwr_idx": 22}
        "radio_1": {
            "enable": true,
            "type": "SX1250",
            "freq": 905000000,
            "tx_enable": false
        "chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
        "chan_multiSF_0": {"enable": true, "radio": 0, "if": -400000},  /* Freq : 903.9 MHz*/
        "chan_multiSF_1": {"enable": true, "radio": 0, "if": -200000},  /* Freq : 904.1 MHz*/
        "chan_multiSF_2": {"enable": true, "radio": 0, "if":  0},       /* Freq : 904.3 MHz*/
        "chan_multiSF_3": {"enable": true, "radio": 0, "if":  200000},  /* Freq : 904.5 MHz*/
        "chan_multiSF_4": {"enable": true, "radio": 1, "if": -300000},  /* Freq : 904.7 MHz*/
        "chan_multiSF_5": {"enable": true, "radio": 1, "if": -100000},  /* Freq : 904.9 MHz*/
        "chan_multiSF_6": {"enable": true, "radio": 1, "if":  100000},  /* Freq : 905.1 MHz*/
        "chan_multiSF_7": {"enable": true, "radio": 1, "if":  300000},  /* Freq : 905.3 MHz*/
        "chan_Lora_std":  {"enable": true, "radio": 0, "if":  300000, "bandwidth": 500000, "spread_factor": 8,						/* Freq : 904.6 MHz*/
                           "implicit_hdr": false, "implicit_payload_length": 17, "implicit_crc_en": false, "implicit_coderate": 1},
        "chan_FSK":       {"enable": false, "radio": 1, "if":  300000, "bandwidth": 125000, "datarate": 50000}						/* Freq : 868.8 MHz*/
    "gateway_conf": {
        "gateway_ID": "E45F01FFFEB95A01",
        /* change with default server address/ports */
        "server_address": "nam1.cloud.thethings.network",
        "serv_port_up": 1700,
        "serv_port_down": 1700,
        /* adjust the following parameters for your network */
        "keepalive_interval": 10,
        "stat_interval": 30,
        "push_timeout_ms": 100,
        /* forward only valid packets */
        "forward_crc_valid": true,
        "forward_crc_error": false,
        "forward_crc_disabled": false,
        /* GPS configuration */
        "gps_tty_path": "/dev/ttyAMA0",
        /* GPS reference coordinates */
        "ref_latitude": 0.0,
        "ref_longitude": 0.0,
        "ref_altitude": 0,
        /* Beaconing parameters */
        "beacon_period": 0,	/* disable class B beacon, set to 128 enable beacon */
        "beacon_freq_hz": 923300000,
        "beacon_freq_nb": 8,
        "beacon_freq_step": 600000,
        "beacon_datarate": 12,
        "beacon_bw_hz": 500000,
        "beacon_power": 27
    "debug_conf": {
        "ref_payload":[
            {"id": "0xCAFE1234"},
            {"id": "0xCAFE2345"}
        "log_file": "loragw_hal.log"
Here is the global_conf.json file that is from the TTN console:
  "SX1301_conf": {
    "clksrc": 1,
    "antenna_gain": 0,
    "radio_0": {
      "enable": true,
      "type": "SX1257",
      "freq": 904300000,
      "rssi_offset": -166,
      "tx_enable": true,
    "radio_1": {
      "enable": true,
      "type": "SX1257",
      "freq": 905000000,
      "tx_enable": false
    "chan_multiSF_0": {
      "enable": true,
      "radio": 0,
      "if": -400000
    "chan_multiSF_1": {
      "enable": true,
      "radio": 0,
      "if": -200000
    "chan_multiSF_2": {
      "enable": true,
      "radio": 0,
      "if": 0
    "chan_multiSF_3": {
      "enable": true,
      "radio": 0,
      "if": 200000
    "chan_multiSF_4": {
      "enable": true,
      "radio": 1,
      "if": -300000
    "chan_multiSF_5": {
      "enable": true,
      "radio": 1,
      "if": -100000
    "chan_multiSF_6": {
      "enable": true,
      "radio": 1,
      "if": 100000
    "chan_multiSF_7": {
      "enable": true,
      "radio": 1,
      "if": 300000
    "chan_Lora_std": {
      "enable": true,
      "radio": 0,
      "if": 300000,
      "spread_factor": 8
    "chan_FSK": {
      "enable": false
    "tx_lut_0": {
      "pa_gain": 0,
      "mix_gain": 8,
      "rf_power": -6,
      "dig_gain": 0
    "tx_lut_1": {
      "pa_gain": 0,
      "mix_gain": 10,
      "rf_power": -3,
      "dig_gain": 0
    "tx_lut_2": {
      "pa_gain": 0,
      "mix_gain": 12,
      "rf_power": 0,
      "dig_gain": 0
    "tx_lut_3": {
      "pa_gain": 1,
      "mix_gain": 8,
      "rf_power": 3,
      "dig_gain": 0
    "tx_lut_4": {
      "pa_gain": 1,
      "mix_gain": 10,
      "rf_power": 6,
      "dig_gain": 0
    "tx_lut_5": {
      "pa_gain": 1,
      "mix_gain": 12,
      "rf_power": 10,
      "dig_gain": 0
    "tx_lut_6": {
      "pa_gain": 1,
      "mix_gain": 13,
      "rf_power": 11,
      "dig_gain": 0
    "tx_lut_7": {
      "pa_gain": 2,
      "mix_gain": 9,
      "rf_power": 12,
      "dig_gain": 0
    "tx_lut_8": {
      "pa_gain": 1,
      "mix_gain": 15,
      "rf_power": 13,
      "dig_gain": 0
    "tx_lut_9": {
      "pa_gain": 2,
      "mix_gain": 10,
      "rf_power": 14,
      "dig_gain": 0
    "tx_lut_10": {
      "pa_gain": 2,
      "mix_gain": 11,
      "rf_power": 16,
      "dig_gain": 0
    "tx_lut_11": {
      "pa_gain": 3,
      "mix_gain": 9,
      "rf_power": 20,
      "dig_gain": 0
    "tx_lut_12": {
      "pa_gain": 3,
      "mix_gain": 10,
      "rf_power": 23,
      "dig_gain": 0
    "tx_lut_13": {
      "pa_gain": 3,
      "mix_gain": 11,
      "rf_power": 25,
      "dig_gain": 0
    "tx_lut_14": {
      "pa_gain": 3,
      "mix_gain": 12,
      "rf_power": 26,
      "dig_gain": 0
    "tx_lut_15": {
      "pa_gain": 3,
      "mix_gain": 14,
      "rf_power": 27,
      "dig_gain": 0
  "gateway_conf": {
    "servers": [
        "serv_enabled": true
