I’ve been chasing this for months and going back and forth trying to figure out the issue. Basically this Spring I replaced my gateway with a RAK2287 using the Pi Hat running Ubuntu and I used the RAK scripts to set it up. The gateway appears to work normally, except some devices like Cubecells very rarely work with it (occasionally I see a join, but not often). I had thought it was a Cubecell issue until this week I picked up a TTIG, and even at several hundred feet away, sitting on the floor in a bad spot, it’s the only gateway seeing the Cubecells (and they work 100% of the time with the TTIG). I have some Dragino sensors/devices, and some Heltec ESP32 based ones with SX1276 working fine with the RAK2287 based gateway. I also am in a rural area, so the only gateways remotely close to me are these only two I have.
- Both Gateways set to US915 TTN
- Cubecells set to US915
board_build.arduino.lorawan.region = US915and auserChannelsMask[6]={ 0xFF00, 0x0000,0x0000,0x0000,0x0000,0x0000 }; - Moving around the Cubecell from close to 100s of feet away makes no difference for RAK2287 reception
- Watching the log output on the Cubcell, it’s transmit to join frequencies appear to be the correct channels when it can’t connect
I feel like I may have a configuration issues on the RAK2287 or TTN registration side as the TTIG works fine, but stumped at what it is. Would appreciate any feedback/suggestions, thank you!
global_conf.json
"SX130x_conf": {
"com_type": "SPI",
"com_path": "/dev/spidev0.0",
"lorawan_public": true,
"clksrc": 0,
"antenna_gain": 0, /* antenna gain, in dBi */
"full_duplex": false,
"fine_timestamp": {
"enable":false,
"mode": "all_sf" /* high_capacity or all_sf */
"radio_0": {
"enable": true,
"type": "SX1250",
"freq": 904300000,
"rssi_offset": -215.4,
"rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d": 2162.56, "coeff_e": 0},
"tx_enable": true,
"tx_freq_min": 923000000,
"tx_freq_max": 928000000,
"tx_gain_lut":[
{"rf_power": 12, "pa_gain": 1, "pwr_idx": 6},
{"rf_power": 13, "pa_gain": 1, "pwr_idx": 7},
{"rf_power": 14, "pa_gain": 1, "pwr_idx": 8},
{"rf_power": 15, "pa_gain": 1, "pwr_idx": 9},
{"rf_power": 16, "pa_gain": 1, "pwr_idx": 10},
{"rf_power": 17, "pa_gain": 1, "pwr_idx": 11},
{"rf_power": 18, "pa_gain": 1, "pwr_idx": 12},
{"rf_power": 19, "pa_gain": 1, "pwr_idx": 13},
{"rf_power": 20, "pa_gain": 1, "pwr_idx": 14},
{"rf_power": 21, "pa_gain": 1, "pwr_idx": 15},
{"rf_power": 22, "pa_gain": 1, "pwr_idx": 16},
{"rf_power": 23, "pa_gain": 1, "pwr_idx": 17},
{"rf_power": 24, "pa_gain": 1, "pwr_idx": 18},
{"rf_power": 25, "pa_gain": 1, "pwr_idx": 19},
{"rf_power": 26, "pa_gain": 1, "pwr_idx": 21},
{"rf_power": 27, "pa_gain": 1, "pwr_idx": 22}
"radio_1": {
"enable": true,
"type": "SX1250",
"freq": 905000000,
"tx_enable": false
"chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
"chan_multiSF_0": {"enable": true, "radio": 0, "if": -400000}, /* Freq : 903.9 MHz*/
"chan_multiSF_1": {"enable": true, "radio": 0, "if": -200000}, /* Freq : 904.1 MHz*/
"chan_multiSF_2": {"enable": true, "radio": 0, "if": 0}, /* Freq : 904.3 MHz*/
"chan_multiSF_3": {"enable": true, "radio": 0, "if": 200000}, /* Freq : 904.5 MHz*/
"chan_multiSF_4": {"enable": true, "radio": 1, "if": -300000}, /* Freq : 904.7 MHz*/
"chan_multiSF_5": {"enable": true, "radio": 1, "if": -100000}, /* Freq : 904.9 MHz*/
"chan_multiSF_6": {"enable": true, "radio": 1, "if": 100000}, /* Freq : 905.1 MHz*/
"chan_multiSF_7": {"enable": true, "radio": 1, "if": 300000}, /* Freq : 905.3 MHz*/
"chan_Lora_std": {"enable": true, "radio": 0, "if": 300000, "bandwidth": 500000, "spread_factor": 8, /* Freq : 904.6 MHz*/
"implicit_hdr": false, "implicit_payload_length": 17, "implicit_crc_en": false, "implicit_coderate": 1},
"chan_FSK": {"enable": false, "radio": 1, "if": 300000, "bandwidth": 125000, "datarate": 50000} /* Freq : 868.8 MHz*/
"gateway_conf": {
"gateway_ID": "REMOVED",
"server_address": "nam1.cloud.thethings.network",
"serv_port_up": 1700,
"serv_port_down": 1700,
/* adjust the following parameters for your network */
"keepalive_interval": 10,
"stat_interval": 30,
"push_timeout_ms": 100,
/* forward only valid packets */
"forward_crc_valid": true,
"forward_crc_error": false,
"forward_crc_disabled": false,
/* GPS configuration */
"gps_tty_path": "/dev/ttyS0",
/* GPS reference coordinates */
"ref_latitude": 0.0,
"ref_longitude": 0.0,
"ref_altitude": 0,
/* Beaconing parameters */
"beacon_period": 0, /* disable class B beacon, set to 128 enable beacon */
"beacon_freq_hz": 923300000,
"beacon_freq_nb": 8,
"beacon_freq_step": 600000,
"beacon_datarate": 12,
"beacon_bw_hz": 500000,
"beacon_power": 27
"debug_conf": {
"ref_payload":[
{"id": "0xCAFE1234"},
{"id": "0xCAFE2345"}
"log_file": "loragw_hal.log"
Gateway log:
*** Packet Forwarder ***
Version: 2.0.1
*** SX1302 HAL library version info ***
Version: 2.0.1;
INFO: Little endian host
INFO: found configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX130x_conf, parsing SX1302 parameters
INFO: com_type SPI, com_path /dev/spidev0.0, lorawan_public 1, clksrc 0, full_duplex 0
INFO: antenna_gain 0 dBi
INFO: Configuring legacy timestamp
INFO: no configuration for SX1261
INFO: Configuring Tx Gain LUT for rf_chain 0 with 16 indexes for sx1250
INFO: radio 0 enabled (type SX1250), center frequency 904300000, RSSI offset -215.399994, tx enabled 1, single input mode 0
INFO: radio 1 enabled (type SX1250), center frequency 905000000, RSSI offset -215.399994, tx enabled 0, single input mode 0
INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8, Explicit header
INFO: FSK channel 8 disabled
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to REMOVED
INFO: server hostname or IP address is configured to "nam1.cloud.thethings.network"
INFO: upstream port is configured to "1700"
INFO: downstream port is configured to "1700"
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: GPS serial port path is configured to "/dev/ttyS0"
INFO: Reference latitude is configured to 0.000000 deg
INFO: Reference longitude is configured to 0.000000 deg
INFO: Reference altitude is configured to 0 meters
INFO: Beaconing period is configured to 0 seconds
INFO: Beaconing signal will be emitted at 923300000 Hz
INFO: Beaconing channel number is set to 8
INFO: Beaconing channel frequency step is set to 600000Hz
INFO: Beaconing datarate is set to SF12
INFO: Beaconing modulation bandwidth is set to 500000Hz
INFO: Beaconing TX power is set to 27dBm
INFO: global_conf.json does contain a JSON object named debug_conf, parsing debug parameters
INFO: got 2 debug reference payload
INFO: reference payload ID 0 is 0xCAFE1234
INFO: reference payload ID 1 is 0xCAFE2345
INFO: setting debug log file name to loragw_hal.log
INFO: found configuration file local_conf.json, parsing it
INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: packets received with a CRC error will be forwarded
INFO: packets received with no CRC will be forwarded
This is uart for GPS.
INFO: [main] TTY port /dev/ttyS0 open for GPS synchronization
CoreCell reset through GPIO17...
Opening SPI communication interface
Note: chip version is 0x10 (v1.0)
INFO: using legacy timestamp
INFO: LoRa Service modem: configuring preamble size to 8 symbols
ARB: dual demodulation disabled for all SF
INFO: found temperature sensor on port 0x39
INFO: [main] concentrator started, packet can now be received
INFO: concentrator EUI: REMOVED
WARNING: [gps] GPS out of sync, keeping previous time reference
INFO: [down] PULL_ACK received in 70 ms
INFO: [modify_os_time] local_time=1635103486, gps_time=1635103482
INFO: [modify_os_time] The difference between the system time(1635103486) and the GPS time(1635103482) is less than 10 seconds. Use the system time.
INFO: [down] PULL_ACK received in 71 ms
What I see on Heltec Cubecell’s with the TTIG shut off:
Copyright @ 2019 Heltec Automation.All rights reserved.
Interrupts attached
AT Rev 1.3
+AutoLPM=1
+LORAWAN=1
+KeepNet=0
+OTAA=1
+Class=A
+ADR=0
+IsTxConfirmed=1
+AppPort=2
+DutyCycle=1200000
+ConfirmedNbTrials=4
+ChMask=00000000000000000000FF00
(Device info removed)
LoRaWAN US915 Class A start!
joining...TX on freq 904700000 Hz at DR 3 power 20 dBm
Event : Tx Done
RX on freq 925700000 Hz at DR 13
Event : Rx Timeout
RX on freq 923300000 Hz at DR 8
Event : Rx Timeout
TX on freq 904500000 Hz at DR 0 power 20 dBm
Event : Tx Done
RX on freq 925100000 Hz at DR 10
Event : Rx Timeout
Event : Rx Timeout
TX on freq 904900000 Hz at DR 3 power 20 dBm
Event : Tx Done
