RAK2246 - Pi Zero pHAT
Hi chaps,
it seems there’s coming up a ‘new kit on the block’ - even smaller for the PiZero:
RAKwireless Documentation Center
Now it will become easy to put the whole gateway into a single tube w/antenna on top.
Im in the process of deciding to buy my first LoRa concentrator board ever for a PiZero.
Would you recommend the RAK2246? I only found it in a kit with a raspi and housing named RAK7246.
Hi lackboden,
personally I use the RAK2245 (since it was available first) but I don’t see any reason why not to start with the RAK2246 which is, as you stated only available with the mentioned kit (at time of writing).
I noted that the link pointer has changed for any reason. Here is a new reference:
https://doc.rakwireless.com/rak7246g-lorawan-developer-gateway/overview
