I have set a rak2245 on a raspberry in order to have a ttn gateway.
It works nice except for one point :
I have change the gateway_id in the json in order to have a nice identification.
I have double checked that the json was effectively changed.
Even with this change when I go on the ttn website to watch the data flow, I see that they all come from the gateway with an identification like “0000000000fffe”.
What software are you running on the gateway? Because it looks like there is an error in the way it determines its unique address. Usually the MAC address of the main Ethernet port is used to base the LoRaWAN EUI on.
BTW, changing it yourself to something that might not be unique is not recommended.
I am just using the software provided by RAKwireless.
I found this morning the following point
I initialy set up the gateway with an eternet connection and there everything is ok.
As I want to install the gateway in a box very close to my outdoor antenna, I switched to wifi for connection to ttn.
With wifi it gives this identification with a lot of zero.
Any help ?
Note that RAK’s concentrator card is fairly generic, you are not limited to using their software but could use anyone else’s raspberry pi setup instructions, too.
The only thing you have to do is figure out the GPIO which reset is connected to, and lower the SPI clock speed in the LoRa HAL library to 2 MHz or even 1 MHz on account of the mistake they made in adding an unnecessary and slow level shifter.
