I found problem to start RAK831 gateway
Normally I use freq: 923-925 Mhz as a long time no problem heppen
but last 2 day ago Resin.io show status “02:09:10 ERROR: [main] failed to start the concentrator”
I try to change router server to another but error that still show
but If I change freg plan to 915 mhz Gateway start normally
How I can solve this problem?
Click to see the full logs
**ERROR when use freg 923-925mhz**
[TTN Gateway]: Resetting concentrator on pin 11
main 02:09:09 *** Multi Protocol Packet Forwarder for Lora Gateway ***
main Version: 3.0.20
main 02:09:09 *** Lora concentrator HAL library version info ***
main Version: 5.0.1; Options: native;
main ***
main 02:09:09 INFO: Little endian host
main 02:09:09 INFO: found global configuration file /opt/ttn-gateway//global_conf.json, parsing it
main 02:09:09 INFO: /opt/ttn-gateway//global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
main 02:09:09 INFO: lorawan_public 1, clksrc 1
main 02:09:09 INFO: 8 LBT channels configured
main 02:09:09 INFO: antenna_gain 0 dBi
main 02:09:09 INFO: Configuring TX LUT with 16 indexes
main 02:09:09 INFO: radio 0 enabled (type SX1257), center frequency 923000000, RSSI offset -166.000000, tx enabled 1
main 02:09:09 INFO: radio 1 enabled (type SX1257), center frequency 922000000, RSSI offset -166.000000, tx enabled 0
main 02:09:09 INFO: Lora multi-SF channel 0> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
main 02:09:09 INFO: Lora multi-SF channel 1> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
main 02:09:09 INFO: Lora multi-SF channel 2> radio 1, IF 200000 Hz, 125 kHz bw, SF 7 to 12
main 02:09:09 INFO: Lora multi-SF channel 3> radio 1, IF 400000 Hz, 125 kHz bw, SF 7 to 12
main 02:09:09 INFO: Lora multi-SF channel 4> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
main 02:09:09 INFO: Lora multi-SF channel 5> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
main 02:09:09 INFO: Lora multi-SF channel 6> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
main 02:09:09 INFO: Lora multi-SF channel 7> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
main 02:09:09 INFO: Lora std channel> radio 1, IF 100000 Hz, 250000 Hz bw, SF 7
main 02:09:09 INFO: FSK channel> radio 1, IF -200000 Hz, 125000 Hz bw, 50000 bps datarate
main 02:09:09 INFO: /opt/ttn-gateway//global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
main 02:09:09 INFO: gateway MAC address is configured to B827EBFFFE847121
main 02:09:09 INFO: Found 1 servers in array.
main 02:09:09 INFO: Server 0 configured to "bridge.asia-se.thethings.network"
main 02:09:09 INFO: filename for statistical performance is configured to "loragwstat.json"
main 02:09:09 INFO: packets received with a valid CRC will be forwarded
main 02:09:09 INFO: packets received with a CRC error will NOT be forwarded
main 02:09:09 INFO: packets received with no CRC will NOT be forwarded
main 02:09:09 INFO: Reference latitude is configured to 16.662141 deg
main 02:09:09 INFO: Reference longitude is configured to 99.586428 deg
main 02:09:09 INFO: Reference altitude is configured to 0 meters
main 02:09:09 INFO: GPS is enabled
main 02:09:09 INFO: Using fake GPS coordinates instead of real.
main 02:09:09 INFO: Upstream data is enabled
main 02:09:09 INFO: Downstream data is enabled
main 02:09:09 INFO: Ghoststream data is disabled
main 02:09:09 INFO: Radiostream data is enabled
main 02:09:09 INFO: Statusstream data is enabled
main 02:09:09 INFO: Beacon is disabled
main 02:09:09 INFO: Packet logger is disabled
main 02:09:09 INFO: Flush output after statistic is disabled
main 02:09:09 INFO: Flush after each line of output is disabled
main 02:09:09 INFO: Watchdog is disabled
main 02:09:09 INFO: Contact email configured to ""
main 02:09:09 INFO: Description configured to "RAK Pilot Gateway "
main 02:09:09 INFO: [Transports] Initializing protocol for 1 servers
main 02:09:10 INFO: [TTN] server "bridge.asia-se.thethings.network" connected
main 02:09:10 INFO: [main] Starting the concentrator
main 02:09:10 ERROR: [main] failed to start the concentrator
**Work Normally when use freq 915 mhz**
*** Resin Machine Info:
main *** Type: None
main *** Arch: None
main *******************
main *** Configuration:
main GW_EUI: *****
main Enabling TTN gateway connector
main *** Fetching config from TTN account server
main Gateway ID: *****
main Gateway Key: ******
main Frequency plan: AU_915_928
main Frequency plan url: https://account.thethingsnetwork.org/api/v2/frequency-plans/AU_915_928
main Gateway description: RAK Pilot Gateway
main Gateway placement: indoor
main Router: bridge.asia-se.thethings.network
main
main Fallback routers:
main mqtts://bridge.eu.thethings.network:8882
main mqtts://bridge.us-west.thethings.network
main mqtts://bridge.brazil.thethings.network
main Latitude: 16.66214098
main Longitude: 99.58642836
main Altitude: 0
main Gateway EUI: B827EBFFFE847121
main Has hardware GPS: False
main Hardware GPS port: /dev/ttyAMA0
main Using fake GPS
main [TTN Gateway]: Resetting concentrator on pin 11
main 02:14:24 *** Multi Protocol Packet Forwarder for Lora Gateway ***
main 02:14:24 *** Lora concentrator HAL library version info ***
main ***
main 02:14:24 INFO: Little endian host
main 02:14:24 INFO: found global configuration file /opt/ttn-gateway//global_conf.json, parsing it
main 02:14:24 INFO: /opt/ttn-gateway//global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
main 02:14:24 INFO: lorawan_public 1, clksrc 1
main 02:14:24 INFO: no configuration for LBT
main 02:14:24 INFO: antenna_gain 0 dBi
main 02:14:24 INFO: Configuring TX LUT with 16 indexes
main 02:14:24 INFO: radio 0 enabled (type SX1257), center frequency 917200000, RSSI offset -166.000000, tx enabled 1
main 02:14:24 INFO: radio 1 enabled (type SX1257), center frequency 917900000, RSSI offset -166.000000, tx enabled 0
main 02:14:24 INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
main 02:14:24 INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
main 02:14:24 INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
main 02:14:24 INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
main 02:14:24 INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
main 02:14:24 INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
main 02:14:24 INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
main 02:14:24 INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
main 02:14:24 INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
main 02:14:24 INFO: FSK channel 8 disabled
main 02:14:24 INFO: /opt/ttn-gateway//global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
main 02:14:24 INFO: gateway MAC address is configured to B827EBFFFE847121
main 02:14:24 INFO: Found 1 servers in array.
main 02:14:24 INFO: Server 0 configured to "bridge.asia-se.thethings.network"
main 02:14:24 INFO: filename for statistical performance is configured to "loragwstat.json"
main 02:14:24 INFO: packets received with a valid CRC will be forwarded
main 02:14:24 INFO: packets received with a CRC error will NOT be forwarded
main 02:14:24 INFO: packets received with no CRC will NOT be forwarded
main 02:14:24 INFO: Reference latitude is configured to 16.662141 deg
main 02:14:24 INFO: Reference longitude is configured to 99.586428 deg
main 02:14:24 INFO: Reference altitude is configured to 0 meters
main 02:14:24 INFO: GPS is enabled
main 02:14:24 INFO: Using fake GPS coordinates instead of real.
main 02:14:24 INFO: Upstream data is enabled
main 02:14:24 INFO: Downstream data is enabled
main 02:14:24 INFO: Ghoststream data is disabled
main 02:14:24 INFO: Radiostream data is enabled
main 02:14:24 INFO: Statusstream data is enabled
main 02:14:24 INFO: Beacon is disabled
main 02:14:24 INFO: Packet logger is disabled
main 02:14:24 INFO: Flush output after statistic is disabled
main 02:14:24 INFO: Flush after each line of output is disabled
main 02:14:24 INFO: Watchdog is disabled
main 02:14:24 INFO: Contact email configured to ""
main 02:14:24 INFO: Description configured to "RAK Pilot Gateway "
main 02:14:24 INFO: [Transports] Initializing protocol for 1 servers
main 02:14:24 INFO: [TTN] server "bridge.asia-se.thethings.network" connected
main 02:14:24 INFO: [main] Starting the concentrator
main 02:14:27 INFO: [main] concentrator started, radio packets can now be received.
main 02:14:27 INFO: [up] Thread activated for all servers.
main 02:14:27 INFO: Disabling GPS mode for concentrator's counter...
main 02:14:27 INFO: host/sx1301 time offset=(1564280065s:370111µs) - drift=1436559359µs
main 02:14:27 INFO: Enabling GPS mode for concentrator's counter.
main
main 02:14:27 INFO: JIT thread activated.
main
main ##### 2019-07-28 02:14:57 GMT #####
main ### [UPSTREAM] ###
main # RF packets received by concentrator: 0
main # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
main # RF packets forwarded: 0 (0 bytes)
main # PUSH_DATA datagrams sent: 0 (0 bytes)
main # PUSH_DATA acknowledged: 0.00%
main ### [DOWNSTREAM] ###
main # PULL_DATA sent: 0 (0.00% acknowledged)
main # PULL_RESP(onse) datagrams received: 0 (0 bytes)
main # RF packets sent to concentrator: 0 (0 bytes)
main # TX errors: 0
main ### BEACON IS DISABLED!
main ### [JIT] ###
main # INFO: JIT queue contains 0 packets.
main # INFO: JIT queue contains 0 beacons.
main ### [GPS] ###
main # No time keeping possible due to fake gps.
main # Manual GPS coordinates: latitude 16.66214, longitude 99.58643, altitude 0 m
main ### [PERFORMANCE] ###
main # Upstream radio packet quality: 0.00%.
main ### [ CONNECTIONS ] ###
main # bridge.asia-se.thethings.network: Connected
main # Semtech status report send.
main ##### END #####
main 02:14:57 INFO: [TTN] bridge.asia-se.thethings.network RTT 43
main 02:14:57 INFO: [TTN] send status success for bridge.asia-se.thethings.network
main 02:15:27 INFO: Disabling GPS mode for concentrator's counter...
main 02:15:27 INFO: host/sx1301 time offset=(1564280065s:370203µs) - drift=92µs
main 02:15:27 INFO: Enabling GPS mode for concentrator's counter.
main
main
main ##### 2019-07-28 02:15:27 GMT #####
main # TX errors: 0
main ### [JIT] ###
main ### [GPS] ###
main 02:15:27 INFO: [TTN] bridge.asia-se.thethings.network RTT 43
main 02:15:27 INFO: [TTN] send status success for bridge.asia-se.thethings.network
main
main ##### 2019-07-28 02:15:57 GMT #####
main # RF packets received by concentrator: 1
main # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
main # TX errors: 0
main ### [JIT] ###
main ### [GPS] ###
main 02:15:57 INFO: [TTN] bridge.asia-se.thethings.network RTT 46
main 02:15:57 INFO: [TTN] send status success for bridge.asia-se.thethings.network
