Thank you, but the win.rar isn’t work, it say that is corrupted.
strange, for me it is ok.
Try to download it again?
Thank you.
I’m starting to test that version
Never joined…
that is something else then ‘file corrupted’ right ?
With the download file, was all right.
But now, my node never reach join.
I’m using AU915 OTAA
Yes, I have my own gateway RAK7249 in my roof…
- I suggest you visit and ask @ the RAK support forum
- I see you did, why , because you have a new product, maybe its defect, and here in this thread most users are still beta testing.
https://downloads.rakwireless.com/en/LoRa/RAK7200-Tracker/Firmware/RUI_RAK7200_V3.1.0.10_release.rar
Does anyone know if you can configure this device to only send LoRa packets when motion is detected? I couldn’t find a clear answer in the documentation.
I’d like to use it to track my golf cart around my property, but don’t want it using battery and sending static GPS coordinates when the cart is sitting in my garage.
Thanks.
new firmware, no release notes
https://downloads.rakwireless.com/en/LoRa/RAK7200-Tracker/Firmware/RUI_RAK7200_V3.1.0.11_Release.rar
Releasenotes are added:
https://downloads.rakwireless.com/en/LoRa/RAK7200-Tracker/Firmware/RAK7200_ChangeLog.txt
2019-12-26 Version:V3.x.0.11
Feature:
1.fix an issue about "at+set_config=device:gps_timeout:X".
2.add a new AT command "at+set_config=device:gps_format:X" so that you can config gps payload format.
X means: <0: LPP format which is only 4 decimal digits accuracy>
<1: 6 decimal digits accuracy>
New firmware available at RAK download site.
https://downloads.rakwireless.com/en/LoRa/RAK7200-Tracker/Firmware/RAK7200_Latest_Firmware.zip
Release notes: 2020-03-04
Firmware package: RAK7200_Latest_Firmware.zip for EU868/US915/AU915/KR920/IN865/AS923 regions.
Firmware Version: V3.X.0.12
BOOT Version: V3.1.1
Feature:
1.Add “gps,voltage,acceleration,magnetic,gyroscope” parameters open/close AT command.
You can use “at+help” command to see more details.
2.Fix the issue about saving the configuration of sensor.
3.Add a method about subcontract when the length of the packet is bigger than the current max payload
Currently under test and need to say it works fine at my site!
Thanks RAK
regards,
Jeroen
And again a new firmware available:
Release:2020-03-20
Firmware Version: V3.X.0.13
Feature:
1.delete LoRaP2P AT command because RAK7200 don’t support LoRaP2P mode
On the RAK-homepage (and Reichelt too) the RAK 7200 is still offered with a barometric sensor. But there is none. Could it be possible to install an additional sensor like BMP380?
Wolfgang
Can anyone explain me what the different GPS Settings do?
at+set_config=device:gps: X Turn on or turn off GPS
• X - 0 : close, 1 : open, 2 : sleep, 3 : standby
close??? open??? sleep??? standby??? Is it the bad Google Translator?
How good is the magnetometer? Want to use the tracker as a stationary sensor.
