I restarted the gateway and packet forwarder and below is the journalctl output. I don’t see any obvious problems other than GPS data not found. Shouldn’t the gateway show “connected” even when there are no active end devices?
Feb 07 23:14:27 rak-gateway systemd[1]: ttn-gateway.service: Succeeded.
Feb 07 23:14:27 rak-gateway systemd[1]: Stopped The Things Network Gateway.
Feb 07 23:14:27 rak-gateway systemd[1]: Started The Things Network Gateway.
Feb 07 23:14:36 rak-gateway sudo[809]: pam_unix(sudo:session): session closed for user root
Feb 07 23:15:01 rak-gateway CRON[886]: pam_unix(cron:session): session opened for user root by (uid=0)
Feb 07 23:15:01 rak-gateway CRON[890]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Feb 07 23:15:01 rak-gateway CRON[886]: pam_unix(cron:session): session closed for user root
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: *** Beacon Packet Forwarder for Lora Gateway ***
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: Version: 4.0.1
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: *** Lora concentrator HAL library version info ***
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: Version: 5.0.1;
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Little endian host
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: found global configuration file global_conf.json, parsing it
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 pa
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: lorawan_public 1, clksrc 1
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: no configuration for LBT
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: antenna_gain 0 dBi
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Configuring TX LUT with 16 indexes
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: radio 0 enabled (type SX1257), center frequency 904300000, RSSI offset -166.0000
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: radio 1 enabled (type SX1257), center frequency 905000000, RSSI offset -166.0000
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: FSK channel 8 disabled
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: gateway MAC address is configured to 0000000000000000
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: server hostname or IP address is configured to "router.us.thethings.network"
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: upstream port is configured to "1700"
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: downstream port is configured to "1700"
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: downstream keep-alive interval is configured to 10 seconds
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: statistics display interval is configured to 30 seconds
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: upstream PUSH_DATA time-out is configured to 100 ms
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: packets received with a valid CRC will be forwarded
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: packets received with a CRC error will NOT be forwarded
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: packets received with no CRC will NOT be forwarded
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: GPS serial port path is configured to "/dev/ttyAMA0"
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Reference latitude is configured to 10.000000 deg
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Reference longitude is configured to 20.000000 deg
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Reference altitude is configured to -1 meters
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: fake GPS is disabled
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Auto-quit after 20 non-acknowledged PULL_DATA
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: found local configuration file local_conf.json, parsing it
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: redefined parameters will overwrite global parameters
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: local_conf.json does not contain a JSON object named SX1301_conf
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway p
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: gateway MAC address is configured to DCA632FFFEF9914C
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: [main] concentrator started, packet can now be received
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Disabling GPS mode for concentrator's counter...
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: host/sx1301 time offset=(1644275668s:643024µs) - drift=-1021023024µs
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: Enabling GPS mode for concentrator's counter.
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: WARNING: [gps] GPS out of sync, keeping previous time reference
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: [modify_os_time] local_time=1644275671, gps_time=1644275670
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: [modify_os_time] The difference between the system time(1644275671) and the GPS
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: [down] PULL_ACK received in 99 ms
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: [down] PULL_ACK received in 11 ms
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: INFO: [down] PULL_ACK received in 24 ms
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: ##### 2022-02-07 23:15:01 GMT #####
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: ### [UPSTREAM] ###
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: # RF packets received by concentrator: 1
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: # RF packets forwarded: 0 (0 bytes)
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: # PUSH_DATA acknowledged: 0.00%
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: ### [DOWNSTREAM] ###
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: # PULL_DATA sent: 3 (100.00% acknowledged)
Feb 07 23:15:01 rak-gateway ttn-gateway[851]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)type or paste code here
