A bike tracker uses GPS to sends its location over LoRa. If a bike is moving (this is detected with an onboard accelerometer) the device sends the GPS coordinates every 2 minutes. If the bike is not moving, the GPS coordinates are sent every hour. Before the device knows the accurate location, the GPS module needs to acquire signals from at least 4 satellites to calculate the location. In this example, this takes 15 seconds. Sending 12 bytes using SF10 takes up 0.4 seconds per packet.
Battery consumption
0,08 mA - Deep sleep mode
50 mA - Active GPS
50 mA - Sending data over LoRa
12 mA - Active LoRaWAN Module for downlink message
How many days will a battery of 600mAh last before it runs our of power if the bike is used 60 minutes a day?
-> I made my calculation and i got 92 days. However the result is wrong. I have also assumed that the receiving window is 41ms@SF10. Does anyone of you would have tried and got different result?
A GPS from cold need to download information on the satellites on their positions etc, this can take 45 seconds or longer. Once it has downloaded this information a lot of GPSs can store it. Remove the main power from the GPS and when it starts up again, as long there is no long off period, the GPS will use the backup satellite information and aquire a new fix very quickly.
Google ‘GPS Hotfix’ for more details.
The speed of hot fix is almost directly related to how good the GPS antenna is, read here for more information;
yes. I’m using a lopy (a micro python thingy) to pack the coordinates into bytes and send it via lora to TTN. Decode it back into coordinates using the ttn payload Formats Decoder/Converter
