I’m currently trying to get a copy of the UplinkMessage object from the uplink_callback method to process some values in some kind of endless loop with the Python API.
My code looks something like this:
import time
import ttn
import csv
import os, sys
import queue
#Configuration data
app_id = "------------------------"
access_key = "--------------------"
message_path = os.path.abspath(os.path.dirname(sys.argv[0]))
message_path += '/messages.csv'
last_message = queue.Queue() #initialises a first in first out queue
#Define uplink method
def uplink_callback(msg, client):
#Create CSV file with message content
with open (message_path,'a',newline='') as message_file:
csv_writer=csv.writer(message_file)
csv_writer.writerow([msg.app_id,msg.dev_id,msg.payload_raw,msg.payload_fields.altitude,msg.payload_fields.hdop,msg.payload_fields.latitude,msg.payload_fields.longitude,msg.metadata.time])
csv_writer.close()
global last_message
last_message.put((msg))
#Create handler for "The Things Network"
handler = ttn.HandlerClient(app_id, access_key, discovery_address="discovery.thethings.network:1900")
#Start mqtt client
mqtt_client = handler.data()
mqtt_client.set_uplink_callback(uplink_callback)
mqtt_client.connect()
while True:
time.sleep(10)
if not last_message.empty():
print(last_message.get())
Despite the “last_message” queue is flagged as global in the uplink_callback method, I wasn’t able to show the data in the endless loop.
Does anyone has an answer to this issue?
