Pycom FiPy unable to connect to TTN
Today I stared working with the TTN to setup a device by using a Pycom FiPy. The connection won’t succeed even though I tried both OTAA and ABP. The codes used in Pyton are the ones from the Pycom website. When using ABP no messages/data show up in the TTN console. When using OTAA the serial output writer keeps saying “Not yet joined…”. The region where im located is covered according to the TNN Mapper.
Does someone has the same issues or a solution to this problem?
Thanks!
If you don’t have your own gateway it is going to be harder to debug as normally we’d rely on seeing what the gateway can hear from your device and what any response might be.
Usually the best thing is to get within 100m or so of a gateway - it’s worth looking on the TTN home page as that usually has more gateways listed from the actual gateway database, not just the ones that have been mapped.
