However, the maps on community pages list some meta information e.g. at https://www.thethingsnetwork.org/community/zurich/
However, I do not fully understand where I would have to specify the various values for those keys. Some seem to come from the information I provide at “General settings” in the TTN gateway console but not all. Then there’s eg. “Placement” which I can define on the gateway console (“Location” page). Yet, on that map it still shows up as “Not specified”.
Can someone maybe shed some light on this? I didn’t find documentation explaining these questions.
However, on the gateway configuration page in the console I activated “Set location manually” as the GW doesn’t have GPS.
Maybe all of this can be traced back to v2 → v3 aftershocks?
And…I just discovered the https://www.thethingsnetwork.org/gateway-data/gateway/<my-gw-id> resource which appears to be what drives the map on the TTN community sites.
The TTS is open-source, so as well as detailing the inconsistencies, you should be making changes to the code to submit them to the main repository it won’t change all by itself. At the minimum you should submit a GitHub issue with details on what you see and what you’d like to see.
