See if we can get this integrated in the Handler. As we use Go there, a compiled language, we can’t really dynamically (de)serialise protobufs, unless I’m not aware of a package that does this in memory. So then, we’d need to use a standardised message format, like Cayenne LPP, with optional fields.
happy to write a labs story - are there specific rules?
The payload functions I generate are pure JS, self-contained and Otto-compatible, so they can be used out of the box with the current console. No need for Go. I think we could integrate it in a way that you can upload a proto file and it populates the payload functions for you - we would even be able to make them much smaller as we could preload protobuf.js into the execution chain of Otto if that was favorable.
TypeError: yargs.usage(...).describe(...).describe(...).describe(...).demandOption is not a function
at Object.<anonymous> (C:\Users\nid\AppData\Roaming\npm\node_modules\ttn-proto-generator\index.js:14:6)
at Module._compile (internal/modules/cjs/loader.js:689:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
at Module.load (internal/modules/cjs/loader.js:599:32)
at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
at Function.Module._load (internal/modules/cjs/loader.js:530:3)
at Function.Module.runMain (internal/modules/cjs/loader.js:742:12)
at startup (internal/bootstrap/node.js:283:19)
at bootstrapNodeJSCore (internal/bootstrap/node.js:743:3)
