I was working with multitech and dragino nodes in an integrated application with cayenne and I had no problem, but 3 days ago in the things network when I am connect to node or some device I do not get the payload of data sent by this, only the start message, as seen in the attached image, but the data or sensor information send with node, does not arrive. what could be happening ?. thank you very much.
no, everything remains the same, even one of the nodes is the multitech mdotbox, which when configured normally always sends the data correctly. It will be a problem of the platform ??
