The RSSI of the message from the node received by the gateway is -45 to -49
The SNR of the message from the node received by the gateway is 7.5 to 10
The backhaul for the gateway is through ethernet and my 1Gb fibre connection at home
Here is an export of the Packet Forwarder log
Feb 25 17:45:42 iotloragateway iot-lora-gateway[666]: 17:45:42 INFO: Disabling GPS mode for concentrator's counter...
Feb 25 17:45:42 iotloragateway iot-lora-gateway[666]: 17:45:42 INFO: host/sx1301 time offset=(1677345759s:662097µs) - drift=20µs
Feb 25 17:45:42 iotloragateway iot-lora-gateway[666]: 17:45:42 INFO: Enabling GPS mode for concentrator's counter.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:45:42 GMT #####
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ### [UPSTREAM] ###
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # RF packets received by concentrator: 1
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # RF packets forwarded: 0 (0 bytes)
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA datagrams sent: 1 (232 bytes)
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA acknowledged: 100.00%
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ### [DOWNSTREAM] ###
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # PULL_DATA sent: 6 (100.00% acknowledged)
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # RF packets sent to concentrator: 0 (0 bytes)
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # TX errors: 0
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ### BEACON IS DISABLED!
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ### [JIT] ###
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 packets.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 beacons.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ### GPS IS DISABLED!
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ### [PERFORMANCE] ###
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # Upstream radio packet quality: 0.00%.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # Upstream datagram acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # Downstream heart beat acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # Downstream datagram content quality for server "eu1.cloud.thethings.network" is 0.00%.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # Downstream radio transmission quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ### [ CONNECTIONS ] ###
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # Semtech status report send.
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ##### END #####
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:46:12 GMT #####
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # RF packets received by concentrator: 0
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1417614787
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1424652923
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1431692019
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1438731131
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: 17:46:42 INFO: Disabling GPS mode for concentrator's counter...
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: 17:46:42 INFO: host/sx1301 time offset=(1677345759s:662135µs) - drift=38µs
Feb 25 17:46:42 iotloragateway iot-lora-gateway[666]: 17:46:42 INFO: Enabling GPS mode for concentrator's counter.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:46:42 GMT #####
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ### [UPSTREAM] ###
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # RF packets received by concentrator: 5
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # RF packets forwarded: 5 (115 bytes)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA datagrams sent: 6 (1413 bytes)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA acknowledged: 100.00%
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ### [DOWNSTREAM] ###
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # PULL_DATA sent: 6 (100.00% acknowledged)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # PULL_RESP(onse) datagrams received: 4 (840 bytes)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # RF packets sent to concentrator: 4 (132 bytes)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # TX errors: 0
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # TX rejected (collision packet): 0.00% (req:4, rej:0)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # TX rejected (collision beacon): 0.00% (req:4, rej:0)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # TX rejected (too late): 0.00% (req:4, rej:0)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # TX rejected (too early): 0.00% (req:4, rej:0)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ### BEACON IS DISABLED!
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ### [JIT] ###
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 packets.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 beacons.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ### GPS IS DISABLED!
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ### [PERFORMANCE] ###
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # Upstream radio packet quality: 100.00%.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # Upstream datagram acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # Downstream heart beat acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # Downstream datagram content quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # Downstream radio transmission quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ### [ CONNECTIONS ] ###
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # Semtech status report send.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ##### END #####
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1445770235
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1452809339
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1459848459
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1466939012
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:47:12 GMT #####
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # RF packets received by concentrator: 4
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # CRC_OK: 75.00%, CRC_FAIL: 25.00%, NO_CRC: 0.00%
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # RF packets forwarded: 3 (69 bytes)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA datagrams sent: 4 (940 bytes)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # PULL_DATA sent: 5 (100.00% acknowledged)
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: # Upstream radio packet quality: 75.00%.
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1478326099
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1485364243
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1492403339
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1499442443
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: 17:47:42 INFO: Disabling GPS mode for concentrator's counter...
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: 17:47:42 INFO: host/sx1301 time offset=(1677345759s:662187µs) - drift=52µs
Feb 25 17:47:42 iotloragateway iot-lora-gateway[666]: 17:47:42 INFO: Enabling GPS mode for concentrator's counter.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:47:42 GMT #####
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ### [UPSTREAM] ###
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # RF packets received by concentrator: 5
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # RF packets forwarded: 5 (115 bytes)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA datagrams sent: 6 (1413 bytes)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA acknowledged: 100.00%
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ### [DOWNSTREAM] ###
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # PULL_DATA sent: 6 (100.00% acknowledged)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # PULL_RESP(onse) datagrams received: 4 (840 bytes)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # RF packets sent to concentrator: 4 (132 bytes)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # TX errors: 0
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # TX rejected (collision packet): 0.00% (req:4, rej:0)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # TX rejected (collision beacon): 0.00% (req:4, rej:0)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # TX rejected (too late): 0.00% (req:4, rej:0)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # TX rejected (too early): 0.00% (req:4, rej:0)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ### BEACON IS DISABLED!
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ### [JIT] ###
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 packets.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 beacons.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ### GPS IS DISABLED!
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ### [PERFORMANCE] ###
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # Upstream radio packet quality: 100.00%.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # Upstream datagram acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # Downstream heart beat acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # Downstream datagram content quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # Downstream radio transmission quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ### [ CONNECTIONS ] ###
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # Semtech status report send.
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ##### END #####
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1506481555
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1513520659
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1520559763
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: src/mp_pkt_fwd.c:1671:thread_jit(): lgw_send done: count_us=1529019956
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:48:12 GMT #####
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # RF packets received by concentrator: 3
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # RF packets forwarded: 3 (69 bytes)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA datagrams sent: 4 (941 bytes)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: # PULL_RESP(onse) datagrams received: 4 (841 bytes)
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: 17:48:42 INFO: Disabling GPS mode for concentrator's counter...
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: 17:48:42 INFO: host/sx1301 time offset=(1677345759s:662249µs) - drift=62µs
Feb 25 17:48:42 iotloragateway iot-lora-gateway[666]: 17:48:42 INFO: Enabling GPS mode for concentrator's counter.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:48:42 GMT #####
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ### [UPSTREAM] ###
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # RF packets received by concentrator: 0
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # RF packets forwarded: 0 (0 bytes)
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA datagrams sent: 1 (232 bytes)
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA acknowledged: 100.00%
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ### [DOWNSTREAM] ###
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # PULL_DATA sent: 6 (100.00% acknowledged)
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # RF packets sent to concentrator: 0 (0 bytes)
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # TX errors: 0
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ### BEACON IS DISABLED!
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ### [JIT] ###
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 packets.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 beacons.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ### GPS IS DISABLED!
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ### [PERFORMANCE] ###
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # Upstream radio packet quality: 0.00%.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # Upstream datagram acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # Downstream heart beat acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # Downstream datagram content quality for server "eu1.cloud.thethings.network" is 0.00%.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # Downstream radio transmission quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ### [ CONNECTIONS ] ###
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: # Semtech status report send.
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ##### END #####
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:49:12 GMT #####
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: 17:49:42 INFO: Disabling GPS mode for concentrator's counter...
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: 17:49:42 INFO: host/sx1301 time offset=(1677345759s:662322µs) - drift=73µs
Feb 25 17:49:42 iotloragateway iot-lora-gateway[666]: 17:49:42 INFO: Enabling GPS mode for concentrator's counter.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ##### 2023-02-25 17:49:42 GMT #####
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ### [UPSTREAM] ###
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # RF packets received by concentrator: 0
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # RF packets forwarded: 0 (0 bytes)
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA datagrams sent: 1 (232 bytes)
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # PUSH_DATA acknowledged: 100.00%
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ### [DOWNSTREAM] ###
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # PULL_DATA sent: 6 (100.00% acknowledged)
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # RF packets sent to concentrator: 0 (0 bytes)
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # TX errors: 0
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ### BEACON IS DISABLED!
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ### [JIT] ###
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 packets.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # INFO: JIT queue contains 0 beacons.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ### GPS IS DISABLED!
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ### [PERFORMANCE] ###
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # Upstream radio packet quality: 0.00%.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # Upstream datagram acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # Downstream heart beat acknowledgment quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # Downstream datagram content quality for server "eu1.cloud.thethings.network" is 0.00%.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # Downstream radio transmission quality for server "eu1.cloud.thethings.network" is 100.00%.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ### [ CONNECTIONS ] ###
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: # Semtech status report send.
Feb 25 17:50:42 iotloragateway iot-lora-gateway[666]: ##### END #####
