Problem receiving confirmation from gateway
Hi everyone, I’m having some trouble receiving donwlink to my node after processing the gateway, I don’t know if something is wrong in my code:
 * Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
 * Permission is hereby granted, free of charge, to anyone
 * obtaining a copy of this document and accompanying files,
 * to do whatever they want with them without any restriction,
 * including, but not limited to, copying, modification and redistribution.
 * NO WARRANTY OF ANY KIND IS PROVIDED.
 * This example sends a valid LoRaWAN packet with payload "Hello,
 * world!", using frequency and encryption settings matching those of
 * the The Things Network.
 * This uses ABP (Activation-by-personalisation), where a DevAddr and
 * Session keys are preconfigured (unlike OTAA, where a DevEUI and
 * application key is configured, while the DevAddr and session keys are
 * assigned/generated in the over-the-air-activation procedure).
 * Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
 * g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
 * violated by this sketch when left running for longer)!
 * To use this sketch, first register your application and device with
 * the things network, to set or generate a DevAddr, NwkSKey and
 * AppSKey. Each device should have their own unique values for these
 * fields.
 * Do not forget to define the radio type correctly in config.h.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// LoRaWAN NwkSKey, network session key
// This is the default Semtech key, which is used by the early prototype TTN
// network.
static const PROGMEM u1_t NWKSKEY[16] = { 0x**, 0x**, 0x**, 0x**, 0x**, 0x**, 0x90, 0xFF, 0x3F, 0x03, 0xB4, 0x4E, 0x**, 0x**, 0x**, 0x** };
// LoRaWAN AppSKey, application session key
// network.
static const u1_t PROGMEM APPSKEY[16] ={ 0x**, 0x**, 0x**, 0x**, 0x**, 0x**, 0x90, 0xFF, 0x3F, 0x03, 0xB4, 0x4E, 0x**, 0x**, 0x**, 0x** };;
// LoRaWAN end-device address (DevAddr)
static const u4_t DEVADDR = 0x*******;  // <-- Change this address for every node!
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
void os_getArtEui(u1_t* buf) {}
void os_getDevEui(u1_t* buf) {}
void os_getDevKey(u1_t* buf) {}
static uint8_t mydata[] = "Hola Alcala, esto parece q funciona!";
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping
  .nss = 15,
  .rxtx = LMIC_UNUSED_PIN,
  .rst = 16,
  .dio = {2,4,LMIC_UNUSED_PIN},
void onEvent(ev_t ev) {
  Serial.print(os_getTime());
  Serial.print(": ");
  switch (ev) {
    case EV_SCAN_TIMEOUT:
      break;
    case EV_BEACON_FOUND:
      break;
    case EV_BEACON_MISSED:
      break;
    case EV_BEACON_TRACKED:
      break;
    case EV_JOINING:
      break;
    case EV_JOINED:
      break;
    case EV_RFU1:
      Serial.println(F("EV_RFU1"));
      break;
    case EV_JOIN_FAILED:
      break;
    case EV_REJOIN_FAILED:
      break;
    case EV_TXCOMPLETE:
      if (LMIC.dataLen) {
        Serial.println(LMIC.dataLen);
      // Schedule next transmission
      os_setTimedCallback(&sendjob, os_getTime() + sec2osticks(TX_INTERVAL), do_send);
      break;
    case EV_LOST_TSYNC:
      break;
    case EV_RESET:
      break;
    case EV_RXCOMPLETE:
      // data received in ping slot
      break;
    case EV_LINK_DEAD:
      break;
    case EV_LINK_ALIVE:
      break;
    default:
      break;
void do_send(osjob_t* j) {
  } else {
    LMIC_setTxData2(1, mydata, sizeof(mydata) - 1, 0);
void setup() {
  Serial.begin(115200);
#ifdef VCC_ENABLE
  // For Pinoccio Scout boards
  pinMode(VCC_ENABLE, OUTPUT);
  delay(1000);
#endif
  // LMIC init
  os_init();
  LMIC_reset();
#ifdef PROGMEM
  LMIC_setSession(0x1, DEVADDR, nwkskey, appskey);
#else
  LMIC_setSession(0x1, DEVADDR, NWKSKEY, APPSKEY);
#endif
#if defined(CFG_eu868)
  // Set up the channels used by the Things Network, which corresponds
  // to the defaults of most gateways. Without this, only three base
  // channels from the LoRaWAN specification are used, which certainly
  // works, so it is good for debugging, but can overload those
  // frequencies, so be sure to configure the full frequency range of
  // your network here (unless your network autoconfigures them).
  // Setting up channels should happen after LMIC_setSession, as that
  // configures the minimal channel set.
  // NA-US channels 0-71 are configured automatically
  LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI);   // g-band
  LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI);  // g-band
  LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI);   // g-band
  LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI);   // g-band
  LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI);   // g-band
  LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI);   // g-band
  LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI);   // g-band
  LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI);   // g-band
  LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK, DR_FSK), BAND_MILLI);    // g2-band
// TTN defines an additional channel at 869.525Mhz using SF9 for class B
// devices' ping slots. LMIC does not have an easy way to define set this
// frequency and support for class B is spotty and untested, so this
// frequency is not configured here.
#elif defined(CFG_us915)
  // but only one group of 8 should (a subband) should be active
  // TTN recommends the second sub band, 1 in a zero based count.
  // https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
  LMIC_selectSubBand(1);
#endif
  LMIC_setLinkCheckMode(0);
  LMIC.dn2Dr = DR_SF9;
  // Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
  LMIC_setDrTxpow(DR_SF7, 14);
  // Start job
  do_send(&sendjob);
void loop() {
  os_runloop_once();
The thing is that, the message sent is correctly received by the gateway and a message confirmation is sent, but it is not received by the node. Moreover, I’ve tried to set DIO2 but always gives me compilation error, no matter where I place the physical connection.
do you have your own gateway?
what do you see in the console?
what is the rssi?
Yes, I have my own one.
It is continuously receiving data but not sending a downlink to the Node
Pd: I’ve followed this tutorial to set up the gateway Tutorial
You are in breach of the TTN Fair Use Policy with the send rate you have - please correct this.
Why are you expecting a confirmation from the gateway?
Why do you want a confirmation?
The FUP allows up to ten downlinks / confirmations per day. The community encourages one a fortnight due to the impact on the network.
Sending text, even for test purposes, is inefficient and even for test purposes, clutters the airwaves. If need a test payload, then three bytes or less are best.
Understood, I haven’t taken it into account when conducting tests. I’ll fix it and migrate my system to OTA (Over-The-Air) to avoid confirmations and I will set a longer send rate in order to obey the Fair Use Policy. Thank you and sorry for any inconvenience caused to the network, I’m new at this.
OTAA has nothing to do with confirmations - nor does ABP - but OTAA has many benefits.
LoRaWAN doesn’t routinely acknowledge an uplink - you will have seen the uplink in the gateway console - that would have just been a record of an incoming uplink.
You may benefit considerably from spending an evening reading this: https://www.thethingsnetwork.org/docs/lorawan/ - most importantly the fundamentals section.
